01-18-2003, 08:27 PM | #1 |
68 front clip on a 69?
I was looking at the new issue of Classic Trucks and saw that phat ass 72 Chevy with a 68 clip. I think by far the best front end is the 68 front. how hard is it to put a 68 nose on a 69? I am hoping it is a matter of just changing the grille.
Second I wanted to pass along to everyone that I tried the roll on herculiner and found it to be a great product. i did two coats in my long bed and still had enough to use as an undercoating for under the cab.
69 Chevy V8 350 (Project Truck) 97 Chevy Blazer LT (Daily Driver) 81 BMW 528i Fully Restored |
01-18-2003, 08:29 PM | #2 |
Used to have a truck
Youd have to change the fenders, grill , gravel pan , radiator support and hood . That is just about the whole front end.
No truck :-( Last edited by mikep; 01-18-2003 at 08:34 PM. |
01-18-2003, 10:03 PM | #3 |
its all about the +6 inches
Easiest way is to do the whole front clip...less work and your sure to get it all in one quick swap.
01-18-2003, 10:34 PM | #4 |
i love summertime
what the f^ck is a gravel pan?
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
01-18-2003, 10:41 PM | #5 |
The F^cking gravel pan is the F^cking sheetmetal piece in front of the F^cking radiator and below the F^cking grill. Its what you set your beer on when working on the engine.
No truck :-( |
01-18-2003, 11:33 PM | #6 |
F^cking beer |
01-19-2003, 01:11 AM | #7 |
So Many Ideas, So Little Money
LOL, the front clip is easy to change though. like 8 bolts after you've removed the cowl and wiring and stuff
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu Marshalltown, Iowa |
01-19-2003, 02:07 AM | #8 |
Fabricate till you "puke"
You just want to be sure to move your beer off the gravel pan while swapping clips.....so you dont spill it....
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
01-19-2003, 11:18 AM | #9 |
So that's what happended to my beer. . . . . . . .
01-19-2003, 02:56 PM | #10 |
Is that what they call beer metal
01-19-2003, 03:48 PM | #11 |
what is the difference between a 69-72 chevy fender and a 69-72 gmc fender?
bogey5 |
01-19-2003, 03:55 PM | #12 |
The '69 - '72 GMC fenders are the same as the '68 Chevy.
01-19-2003, 04:18 PM | #13 |
So Longhorn. If I wanted a fender for a 67. Could I buy a 69-72 GMC fender and fill the marker light right? Is anything GMC equivalent to a 67 chevy?
Thanks Brandon |
01-19-2003, 04:28 PM | #14 |
Bingo.
01-19-2003, 05:06 PM | #15 |
Thanx.
Brandon |
01-19-2003, 11:35 PM | #16 |
amazing what this addictive damn site teaches ya!
01-20-2003, 12:19 AM | #17 |
has anyone seen a 67-72 truck with the 67-68 grill and hood with the top and bottom moldings like the 69-72 chevy has down the side? Wonder what it would look like?
bogey5 |
