10-25-2009, 11:48 PM | #1 |
Noisy fan
My C10 69 does not has fan clutch and is too noisy specially on the highway Í´d like in the future install electric fan how I saw in a topic at this forum but for a while do you think can I use one w/ fan fan cluth?
10-26-2009, 01:51 PM | #2 |
Re: Noisy fan
Kind of hard to understand exactly what you want, but I think you are trying to decide between doing an electric fan or a fan clutch. I went with a fan clutch and the noise level dropped by probably 70%. I'm sure an electric fan would be even more, but I didn't feel it was worth the effort.
10-26-2009, 02:52 PM | #3 |
Re: Noisy fan
OK my truck rightknow has a seven blades fan without cluth probably old version for inmediately I´d like to install one with clutch while I´ve money to instal an electric fan, so I want to know if any from a C10,C20,suburban or jimmi 87-83 will fit?
10-26-2009, 02:58 PM | #4 |
Re: Noisy fan
It's more of a clearance issue between the crank pulley, and also the radiator. Part of this is determined by whether you have a short or long water pump. The other is determined by the spacing on the clutch. What I did is I drove the truck into my local auto parts store (a REAL one, not Pecker Bros!) and had them look at it. The guy was able to find one with the proper spacing so it cleared everything.
10-27-2009, 09:34 AM | #5 |
Re: Noisy fan
This past winter I pulled the Original fan and replaced it with an electric fan from a Subaru that I had laying around. The Subaru used two fans and I used the larger of the two. It works well and quiet at highway speed, then again it never turns on at Highway speed. On the 292 a fan is superfluous if you are moving and just robs power and fuel economy.
DIY body and paint work is cheap, making it look good... priceless -------------------------------------------- My Toys; ’26 Ford Model T ‘72 Triumph Spitfire 1500 '09 "The Briggs Flyer" Gettin' High. Last edited by '68 C-20; 10-27-2009 at 09:34 AM. |
10-27-2009, 01:07 PM | #6 |
Re: Noisy fan
thanks 68 C20, I just have a question. Subaru car or SUV?
10-27-2009, 01:39 PM | #7 |
Between Trucks...
Re: Noisy fan
I'm running a nylon flexfan the P.O. installed. No clutch, quiet and keeps the motor at 190 degrees.
Beat it to fit, Paint it to match... |
10-27-2009, 02:10 PM | #8 |
*** That's interesting ***
Re: Noisy fan
I have a '69 C30 that is capable of hauling twice its weight. With a car on the back, going up hill, my 350 (underpowered and working hard) stays perfectly cool with the stock 7-blade configuration and heavy duty clutch under those conditions. Those clutches are easy to find at most parts stores, and as other people have said, it's just a matter of finding the correct shaft length. If you go with a vendor like Hayden (which makes many of them for the chains), they even have specs on their website for each clutch part number and application. Some of the Hayden clutches are a little iffy in quality (there have been some bad runs over the years), so it's not uncommon to need to try one or two before you get one that behaves properly.
I am a fan of electric fans (no pun intended) on modern engines, but a good stock mechanical fan with a clutch usually just works without hassle.
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... Last edited by storm9c1; 10-27-2009 at 02:11 PM. |
10-27-2009, 03:43 PM | #9 |
Re: Noisy fan
Car, I don't recall what model. My Daughters ex-boyfriend left one on my property after the split up. After two months of looking at it, I stripped it of anything I thought I could use and called a junker to haul it off.
It had two fans i took them both. I put the larger on on the C-20. Currently it is in front of the radiator. It can be wired to blow in or out. It seems to move a little more air blowing out so I set it up that way. It cools the engine fine, even in the city, idling in August the temp does not exceed what is was with the original rigid fan, Why in front of the radiator? It was easier to mount without making use of existing holes with no modification to the truck, mine is original and I try not to drill extra holes if possible. The 292 does not use a fan shroud, the 350 did. I just picked up a plastic 350 fan shroud . This winter I will mount the electric fan inside the fan shroud and put it on the Engine side of the radiator, that will keep it out of site as well. I am pretty sure the 350 fan shroud will bolt into the truck with no modification either.
DIY body and paint work is cheap, making it look good... priceless -------------------------------------------- My Toys; ’26 Ford Model T ‘72 Triumph Spitfire 1500 '09 "The Briggs Flyer" Gettin' High. Last edited by '68 C-20; 10-27-2009 at 03:45 PM. Reason: Spelling Duooh! |
10-27-2009, 05:05 PM | #10 |
Hollister Road Co.
Re: Noisy fan
Try a 95 Cougar XR7 fan, Its identical to the two speed MarkVIII fan and is a very easy install. They are about $70 from Rockauto.com part is #620950
10-27-2009, 06:59 PM | #11 |
Re: Noisy fan
i have a 4 blade fan on my truck that does not have a clutch on it, and it isn't loud at all
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
