Th350 vs th400
Hello everyone I have been reading the forumn about th350 and th400 because i have herd that th350 isnt good for mudding trucks and towing stuff and then a couple of my buddies said stay away from th400s!!
So anyone who has had experience with theses trannys please feel free and let me know your opion on how good and strong they are and ect thanks in advance |
Re: Th350 vs th400
find new buddies
Re: Th350 vs th400
whats there reasons for staying away form the 400
diy or die |
Re: Th350 vs th400
The only reason for staying away from a 400 (that I can think of) is that they suck up more horsepower than a TH350.
If you are on the ragged edge in a timed competitive event, like NHRA drag racing, there might be an advantage to changing. However, for the street or some activity where it's purely subjective, the TH400 is a heavier duty trans and you are less likely to tear it up in a heavy, high performance vehicle. The stock TH350 also has a little bit steeper first gear compared to the TH400 (2.52:1 first vs a 2.48 first, respectively). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#5 | |
Re: Th350 vs th400
Re: Th350 vs th400
yes the 400 sokes up a tuch more power but with more clutch discs in the transmision they are hader to brake so is there any bennift to switching kinda more clutch disc can handle more power so if ur bulding alot of power id switch
diy or die |
Re: Th350 vs th400
Re: Th350 vs th400
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Th350 vs th400
Ive owned both th 400 and th 350 trans. the th350 i can tare up in a year the th 400 takes longer..I tow all kinds of junk and haul stuff way to heavy for it and the th400 is pretty well bulletproof
Re: Th350 vs th400
th400 was in 3/4 and 1 tons for a reason
Re: Th350 vs th400
The Th350 in my 84 lasted 250k before it went out.
Watchin the rust grow
![]() Join Date: Oct 2008
Re: Th350 vs th400
Shift kit in either of them and they should last you a good while.
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000) 1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000) 1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850) 1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done ![]() 2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now Underneath that rust is a heart of gold
#13 |
Slugish
![]() Join Date: Jan 2005
Re: Th350 vs th400
#14 |
3/4 Ton Rodder
Re: Th350 vs th400
Mine has a TH400 in it and it is good, but I think GM could've improved it by adding an overdrive from the factory. Do they make an add-on overdrive for the TH400?
1981 Chevy Scottsdale C20 "Orange Crush": SOLD 1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy. |
#15 |
Re: Th350 vs th400
Yo! I'm quite satisfied with the TH350 in my 325-350hp '76 Camaro, and the TH400 in my '78 (same engine) K20 longbed.
35,000+ street/strip on the Camaros',...the truck is just getting started back on the road. The Camaros' TH350 and 2.79 rear gears make it quite the road car with the power to turn those low gears. I shift it manually down a gear to pass and get about 15.5mpg ruling the road. The FRANKENTRUCK doesn't do as well with the TH400, even with 33" tires,...with 4.11 front/rear gears, the lack of an overdrive causes the 350V8 to run at about 3200rpm at 75mph, but damned if it doesn't accelerate quickly off the line! I expect to lower it's axle gear ratios to 3.42. Both trannys lack overdrive but are tough as nails! Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK! Last edited by asphaltburner; 10-26-2009 at 11:52 PM. |
