Old 10-26-2009, 03:40 PM   #1
BTCHN 1963
BTCHN 1963's Avatar
Barn doors to tailgate
I am new to this forum and had been rooting around trying to find if anyone has done a conversion from barn doors to a tailgate on a 73-91 suburban.
I just picked up a 1990 chevy suburban 1/2 ton with barn doors. My current plan is to convert it over to 3/4 ton suspension, add a 4" lift and possibly convert the barn doors to a tail gate. I have done the suspension swaps and lifts on other chevy square bodies so that is not a problem. I just need suggestions or a link to someone who has converted from barn doors to a tailgate to see if it is something I want to do. If you think it is a bad idea due to historical problems with tailgates please say so.
I will add some pictures later when I get home.
Thanks!
BTCHN 1963 is offline   Reply With Quote
Old 10-26-2009, 07:28 PM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Barn doors to tailgate
I am not sure about this, but I think they made some work burbs with doors like that. Or am I thinking of something dif?
tvblazer78 is offline   Reply With Quote
Old 10-26-2009, 09:16 PM   #3
trenchwarfare
What???
There are barn doors or a tailgate option, completely different mounts. I'd check out photos.
____________________________________
trenchwarfare is offline   Reply With Quote
Old 10-27-2009, 08:45 AM   #4
BTCHN 1963
BTCHN 1963's Avatar
I realize that the mounting of the rear barn doors and the tailgate are different. I have a 1963 suburban that I changed from barn doors to tailgate. The mounting was there for both but the holes were not drilled. I was thinking that it would be a similar change over. It looks like the tailgate version, from what I remember, has an extra metal piece around the upper half of it to form the seal area for the window. Other than that the bottom looks about the same. I don't have a tailgate version to look at more closely. May be someone can post some pics of a tailgate version so I can see the difference?
Old 10-27-2009, 09:09 PM   #5
87 dually burb
my short bus
87 dually burb's Avatar
from what i could find 83 was the last year with both mounts in burbs
my 90 only had tail gate mount i was going to change them but didn't
i also thing the floor metal is different where it closes at bottom
**90 burb**bagged,shaved**(about done)*********
**91 burb**stock worker for now****************
*********only squares for me******************
87 dually burb is offline   Reply With Quote
Old 10-28-2009, 08:51 AM   #6
BTCHN 1963
BTCHN 1963's Avatar
Wow, thanks 87 dually burb! I am picking up a parts suburban with big brake 3/4 ton suspension, 4 inch lift and tailgate. I will be able to have them side-by-side and see if changing to a tailgate is reasonably doable. I will pay close attention to the bottom to see how close they are.
Old 10-29-2009, 06:05 PM   #7
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
From the ones I have had it stopped around 1978.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 10-31-2009, 09:00 PM   #8
USSkoval
Now this is uncharted territory. It is known that the older burbs had the correct holes for both. We also know that newer tailgate models do not have the holes for the barn door hinges. But do the barn door models have the threaded holes under the body for a tailgate? I would think they do. I believe the needed upper window frame just gets screwed in place with sheet metal screws, so that shouldn't be a big deal. I think the lower sill could easily me modified to work since it doesn't really do anything, other than support the tension springs.
I say go for it! I love my tailgate. Sure, I had several problems with the power window when I got the Burb, but that was mostly because of the previous owner's lack of maintenance. It was well worth the trouble and expense.
USSkoval is offline   Reply With Quote
Old 11-02-2009, 10:04 AM   #9
BTCHN 1963
BTCHN 1963's Avatar
Thanks for the support USSkoval! I will let you know how it looks when I get the parts Burb to my house.
The real reason for the tailgate is that I haul lumber and materials for building custom horse stalls and our last suburban had barn doors and they were not as friendly when I had material longer than what would allow the doors to close. Also I like being able to roll down the window and let the air blow through like on my blazer.
Old 11-02-2009, 06:28 PM   #10
87 dually burb
my short bus
you could always build a receiver hitch to support the lumber
but I'm not talking you out of the swap
Old 11-02-2009, 09:50 PM   #11
USSkoval
I went out yesterday and took a good look at my Burb. I then realized I had completely forgot about the strikers and the limiting straps. It still shouldn't be a big deal, especially if you can cut and weld.
Old 11-08-2009, 12:46 PM   #12
SBTork
Garage wrench
SBTork's Avatar
Anymore news on this, im intersted aswell
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 11-08-2009, 07:06 PM   #13
Gemp
Gemp's Avatar
I would like to go the other way....I wanted barn doors, But my tailgate Burban was to clean to pass up.
06' GMC 1500 Crew cab.....
Gemp is offline   Reply With Quote
Old 11-09-2009, 09:44 AM   #14
BTCHN 1963
BTCHN 1963's Avatar
No updates yet. The Body I was to pick up was sold out from under me so now I am looking for another.
