Old 10-26-2009, 06:25 PM   #1
Dark Knight
Dark Knight's Avatar
need some advice...
I've got a 250 I6 with a slipped harmonic balancer. So...I have to buy a new one. My question is, how do yall guys go about installing one? On my Jeep I could just use a long bolt in the end of the crank and just suck it up to the engine. The Chevy crank is just an inverted cone with no bolt to hold on the balancer. Just a press fit. Any suggestions are welcome.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS
-1983 Chevy Silverado C1500- 383 stroker, TH400
-1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears
-And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket
"The only thing we have to fear is fear itself." -FDR (and maybe rust too)
You've gotta be able to stop and steer before you can go fast!
Dark Knight is offline   Reply With Quote
Old 10-26-2009, 06:27 PM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: need some advice...
Try using a harmonic balancer installer tool
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 10-26-2009, 06:42 PM   #3
Dark Knight
Can't. It uses threads in the end of the crank to push the balancer on. Threads that I don't have... Last time I just used a block of wood and a hammer. It's probably not the "correct" way, but it got the job done. And the engine never gave me any problems...until now. It's a 40+ year old balancer anyway. It was going to go out sooner or later.
Old 10-26-2009, 08:00 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Put the balancer in the oven for about 15 min.Don't set the temp too high but warm it up good.Use a pair of welding gloves and do it on a cold day.You'll probably still have to tap it on with a hammer and block of wood but not as hard.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-26-2009, 08:03 PM   #5
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
sledge hammer and block gets mine on everytime, never thought about heating it,,,,
Good tip Panel D.....
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 10-26-2009, 08:07 PM   #6
68gmsee
Active Member
68gmsee's Avatar
The way I've done it: Remove the radiator first it will be a lot easier and prevent damaging it. Then go get a big heavy duty hammer- not a carpenter's or ball peen one. With a flat piece of 2X4 bang it in. Once it's started, you can tap it in but be careful not to hit the outer ring.
Now, the way you should do it: Have a machine shop drill and tap the end of the crank.
A lot of guys have used the bang it in method with no problems. The only time I had a problem is when the 2X4 slipped and I messed up the balancer...
68gmsee is offline   Reply With Quote
Old 10-26-2009, 09:40 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Another easy way is to buzz it into place with an air hammer and a wide flat bit.
I've got one like number 5. It works great.
Old 10-26-2009, 10:21 PM   #8
Dark Knight
Thanks for all the suggestions guys. I think I'm going to go with Panel Deland's idea. I'll also throw a new seal in for good measure. While I'm at it, I'll replace the valve cover gasket, water pump, manifold gasket, touch-up the paint on the front of the engine.... You know how it goes. These trucks are never ending projects. Just when you think you've done everything that you could possibly do, something new pops up.
Old 10-26-2009, 11:19 PM   #9
mclairmo
I thought that hammering on it could screw up the end play of the crank against the main thrust bearing and/or damage the main bearings.
mclairmo is offline   Reply With Quote
Old 10-26-2009, 11:24 PM   #10
BOOB
BOOB's Avatar
This is the safest way to do it. It's actually in older repair manuals. Tons of older motors, like the 265 in my Bel Air, have press on balancers. DONT hit it metal to metal, I use a dead blow plastic mallet. It wont hurt anything.
1970 Short/Fleet C-10 (Project)
-Slammed and Tubbed
1955 Cameo
-Straight six, Turbo Hydro option
1955 BelAir 2 door post
-All original down to the oil bath air cleaner
1964 Corvette
-All power A/C 327 4 spd. tanker
BOOB is offline   Reply With Quote
Old 10-27-2009, 09:19 AM   #11
'68 C-20
'68 C-20's Avatar
If you hammer it on, how do you line up timing mark with any reasonable degree of accuracy?
DIY body and paint work is cheap, making it look good... priceless
My Toys;
’26 Ford Model T
‘72 Triumph Spitfire 1500
'09 "The Briggs Flyer" Gettin' High.
'68 C-20 is offline   Reply With Quote
Old 10-27-2009, 09:27 AM   #12
Dark Knight
It lines up with a key in the crank. I've done this before, just wanted to see if there was an alternate method of installation. I really don't like hammering it on, but it seems to be the only way. I guess the engineers at GM designed it this way because they knew that the I6 was bulletproof.
Old 10-27-2009, 09:38 AM   #13
'68 C-20
'68 C-20's Avatar
So if your outer ring has slipped, can you pull the Balancer and re-build it and put it back together to put the outer ring where the timing mark ought to be? Or do you have to replace it?
My Toys;
’26 Ford Model T
Old 10-27-2009, 09:48 AM   #14
BOOB
BOOB's Avatar
As far as I know you dont rebuild a balancer.
-Slammed and Tubbed
1955 Cameo
1964 Corvette
