Old 10-26-2009, 08:22 PM   #1
lo72
Truck Junkie
lo72's Avatar
Sway bar mounts
I have a 70 c-10 that i'm putting 90 model suburban crossmember setup in. This truck did'nt come with a swaybar or the frame brackets. Do i need them or the lowered ones? It is bagged with plates and cups. can I bolt the swaybar directly to the frame or should i get the brackets. Thanks Greg
lo72 is offline   Reply With Quote
Old 10-26-2009, 09:14 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Sway bar mounts
I would bolt it directly to the frame on a bagged truck.
Purchase some good Polyurethane bushings.
I believe you will have to cut the ends of the sway bar off a little (1-1/8" on each end) to keep them from coming in contact with the bags.
There is a thread on here about that subject.
Look here:
http://67-72chevytrucks.com/vboard/s...light=sway+bar
Keith
Convert to disc brakes.
Old 10-26-2009, 09:23 PM   #3
jholley
jholley's Avatar
Re: Sway bar mounts
Get the lowered ones. Also, you'll have to drive out the two rivets that hold the bottom of the front crossmember out. That is where the back of the stock or lowered sway bar mounts bolt to.
Jim
Garage fillers...
85 Chevy C10 Silverado LWB
07 Nissan Altima
2006 Mini Cooper S
jholley is offline   Reply With Quote
Old 10-26-2009, 09:34 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Sway bar mounts
Both ways will work, but you don't "need" the brackets on a bagged truck.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-27-2009, 07:54 PM   #5
lo72
Truck Junkie
lo72's Avatar
Re: Sway bar mounts
thanks for the replies, i'm gonna replace the bushings and go directly on the frame...thanks again!
