Old 10-26-2009, 09:26 PM   #1
pmercer
Column Swap Original Steering Wheel
I am replacing my 3 on the tree with a 700r4. What is the best column swap if I wanted to reuse my original steering wheel.
Peter
pmercer is offline   Reply With Quote
Old 10-26-2009, 10:10 PM   #2
LILRED66
LILRED66's Avatar
Re: Column Swap Original Steering Wheel
A direct bolt-in would be a '60-'66 Chevy/GMC automatic column, but there are other options. The shift indicator on the 2-speed Powerglide says P R N D L and the 3-speed Turbo Hydra Matic says P R N D L2 L1, so you will have to make due or come up with another indicator.
LILRED66 is offline   Reply With Quote
Old 10-26-2009, 10:11 PM   #3
brawley
Easy Does It
brawley's Avatar
I replaced mine with one out of a junk yard. 73-87 chevy or gmc trucks,or vans work great and have tilt column and you can still use your original wheel.
brawley is offline   Reply With Quote
Old 10-26-2009, 10:41 PM   #4
c10Mang
c10Mang's Avatar
I also need to do this.. Was this hard to install??
Thanks,
c10Mang is offline   Reply With Quote
Old 10-27-2009, 02:14 AM   #5
63deluxfleet
63deluxfleet's Avatar
just a note that these columns have the key in the column...look for 70's vans, they have tilt and they are keyless, you can cut em down too. i believe there is a thread some where on this.. feel free to chime in guys
A girl phoned me the other day and said... Come on over, there's nobody home. I went over. Nobody was home. -Rodney Dangerfield
.......THE ROAD TO HELL IS PAVED WITH GOOD INTENTIONS.....
63deluxfleet is offline   Reply With Quote
Old 10-27-2009, 06:05 AM   #6
pmercer
Thanks guys. How about some photos of the install.
Peter
Old 10-27-2009, 06:45 AM   #7
62 short step
62 short step's Avatar
I used a 72 column with my stock wheel. This is the only pic i have now.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 10-27-2009, 10:53 AM   #8
pmercer
Any modifications to the steering wheel to get the horn to work? Or will it work with the '72 column?
Peter
Old 10-27-2009, 12:08 PM   #9
DPowers
DPowers's Avatar
Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=362864
DPowers is offline   Reply With Quote
Old 10-27-2009, 12:10 PM   #10
jchav62
1962 C-10
jchav62's Avatar
I agree with Tony. No mods, and they look the best IMO. Also, I think LMC or one of those companies sells a replacement shift indicator for OD transmissions.
Good luck with whatever route you take...Here's the one we have in the '65...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 10-27-2009, 07:52 PM   #11
brawley
Easy Does It
brawley's Avatar
Yes the 70's vans are best, get the whole section. sterring wheel down to the rag joint at the sterring box. when swaping back to the old wheel just leave the newer horn contact in place and it will work fine
Old 09-20-2010, 07:43 PM   #12
enick72
enick72's Avatar
I just got a 78 doner truck and am thinking of doing a complete swap with auto trans into my 65. When swapping the column what were the major differences or mods you had to make?
55 Chevy 1st series
65 Chevy stepside short bed
www.bigslikpokertables.com
enick72 is offline   Reply With Quote
Old 11-27-2010, 11:14 PM   #13
scum1
scum1's Avatar
i know this is an old thread, but i was wondering if i could swap the steering wheel, in my 63'. im not sure what the differences were between years. but mine has power steering and its a th400 trans so it has the indicator above..it has a grant gt style wheel in it. wanna put an older one. impala style maybe..what would be the easiest swap.. sorry i have ZERO exp. with these kind of things!
scum1 is offline   Reply With Quote
Old 11-28-2010, 12:25 PM   #14
markeb01
Senior Enthusiast
markeb01's Avatar
Post #3 on the following thread points out some issues you should be aware of:
http://67-72chevytrucks.com/vboard/s...teering+column
