Old 10-26-2009, 10:49 PM   #1
justpball
justpball's Avatar
Window how to?
does anyone have a how to on replacing the window regs?
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 10-27-2009, 08:55 AM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Window how to?
Anyone?
tvblazer78 is offline   Reply With Quote
Old 10-27-2009, 09:15 AM   #3
justpball
justpball's Avatar
Re: Window how to?
i just need to put my doors back together and need to know how it all goes back in, like what order...do you put the regulator in then the window and stuff like that...someone should have a how to on that...
87 Crew SWB
Build for the crew
90 burb 2wd
Old 10-27-2009, 09:32 AM   #4
Jonboy
Slots go on anything!
Re: Window how to?
IIRC, you have to set the regulator in the door (maybe hold it with one or two bolts if you don't have an extra set of hands), put the glass on the rollers, then put in the vent glass. It's been a while since I put one together. I would suggest putting in the locks and handle first, while you have the room.
Old 10-28-2009, 12:31 AM   #5
Daggar
Daggar's Avatar
Re: Window how to?
I will probably get shot for this but...
Straight out of my 91 Manual...Hope it helps
The following images are Copyright 1990 General Motors Corporation and have been posted for Research purposes only
1999 Chevrolet Suburban 2500 4x4 - 454, 4L80E and lots of other fun options
1967 Chevrolet C10 Longbox Stepside - Restored
1991 Chevrolet Suburban 2500 4x4 - 350, 4L80E - Not dead but severly crippled
1987 GMC Suburban 1500 - Now some retired guy's trailer hauler
1992 Lumina Z34 - I'll miss that PITA
Daggar is offline   Reply With Quote
Old 10-30-2009, 11:27 AM   #6
justpball
justpball's Avatar
Re: Window how to?
Thanks dagger!
87 Crew SWB
Build for the crew
90 burb 2wd
