Old 10-27-2009, 01:25 AM   #1
BIG KRIS
BIG KRIS's Avatar
Dropmember and static drop
Is anyone running a static drop using the front porterbuilt dropmember?
BIG KRIS is offline   Reply With Quote
Old 10-27-2009, 06:31 AM   #2
vegaschevy
Re: Dropmember and static drop
Im sure Nate will chime in with a few pics of what it looks like. Ill be going this route on my truck eventually as it allows you with Porterbuilts design to run a big block or LS motor with a quick change of the motor mounts
vegaschevy is offline   Reply With Quote
Old 10-29-2009, 12:31 PM   #3
Custom 68
Custom 68's Avatar
I am curious too, I would think coil overs would be a great setup.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 10-29-2009, 01:13 PM   #4
PBFAB.COM
PBFAB.COM's Avatar
The coil-over Dropmember still has a couple small tweaks I making to the upper coil-over mount.
As for the "static" that Kris was referring to, I had mentioned to him that there have been a number of DM owners who elected to bi-pass an air management system and use a schrader valve set-up for a "static" height, with the option for adjusting it with a shop compressor.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 10-30-2009, 02:07 AM   #5
BIG KRIS
BIG KRIS's Avatar
Why thank you Natehen for clearing that up for me as we both know i'm taking bagging 101So there will be a DROPMEMBER that one can use coil overs huh?
