10-27-2009, 04:02 AM | #1 |
What have I gotten into
Easiest way to clean frame?
Back to work on the 72' and I'm trying to clean up the frame while I don't have a bed on it. This is not a frame off resto. But I want to throw some rustoleum roll on paint on the frame, as much as I can get to that is. Anyhow, what's the first step you guys take in getting the layer of built up dirt/roadscum off the frame? I've been just taking a paint scraper and wire brush to most of it. Using a flapper wheel for the easy to get to spots. I didn't know if there was any liquid type solution you guys used to spary on the frame first to get a head start. There is really not a lot of rust, mainly dirt. Any tips is more than welcome.
Thanks Kevin |
10-27-2009, 05:52 AM | #2 |
Re: Easiest way to clean frame?
i use a putty knife to scrape off the bigger accumulations then a few cans of easyoff oven cleaner and a good powerwashing
10-27-2009, 05:55 AM | #3 |
its all about the +6 inches
don't use easy off, get the real cheap nasty oven cleaner... it works better
10-27-2009, 08:51 AM | #4 |
Powerhouse oven cleaner from the dollar store, 1 hour of patience, pressure washer, foam brushes, eastwood chassis black and rust convertor. Result is fabulous. I hit the frame with some sandpaper wiped it down with some mineral spirits applied the coating as prescribed. Forget the scraping and wire wheel time.
10-27-2009, 09:12 AM | #5 |
Ive always had good luck with Kerosene.. Soak the frame down in the morning then again in the afternoon... The next day the stuff comes off pretty easy... Works great on undercoating too..
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
10-27-2009, 10:07 AM | #6 |
I have to do the same thing , but I was wondering if there's a little bit tidier way to do this - as soon as you put solvent on something, you have a big gooey mess, and my wife is not fond of those in the garage. Is it possible to scrape it, or at least keep it in a more clean-upable form?
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
10-27-2009, 10:20 AM | #7 | |
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... 71 LWB |
10-27-2009, 10:22 AM | #8 |
The Red Menace
X2 - Easy Off isn't really that good. Mr. Muscle used to be my favorite for jobs like this. It was probably too strong because I think they took it off the market.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current) 1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former) 1968 C-20 - 307/3sp column (Dad's when I was a kid) "Driving is like coloring. Things get messy if you can't stay inside the lines." |
10-27-2009, 10:24 AM | #9 |
or you can get a sandblasting attachment for a power washer
10-27-2009, 10:29 AM | #10 |
Use the trick they do in the wood shop. Put on the solvent or stripper let it sit then rub it down with sawdust, or use cat litter (cheap stuff) for some abrasive action. then wash it down and repeat.
Or the other option is to send the wife to Vegas for the weekend. |
10-27-2009, 11:29 AM | #11 |
Lay plastic down,then plywood if you can.i have old plywood for throwing under vehicles,etc.It`s so easy to clean up and the plywood can take whatever you give it.
10-27-2009, 12:42 PM | #12 |
Moderator
x 2 on this. I had to do a lot of clean-up in the garage on my frame and this keeps the floor clean and the wife happy.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
10-27-2009, 01:25 PM | #13 |
Awesome advice. But my only issue is that right now the truck don't run and I can't really get it out of the drive. So no powerwashing. Any alternative to powerwashing that I can do?
Headed to the store to get over cleaner now!!!! Thanks |
10-27-2009, 01:30 PM | #14 |
Be careful with the oven cleaner. It eats of EVERYTHING. It will take you frame down to bare metal in some spots. Thats all I use. Wear a respirator if you have one, it will jack up your throat.
1970 Short/Fleet C-10 (Project) -Slammed and Tubbed 1955 Cameo -Straight six, Turbo Hydro option 1955 BelAir 2 door post -All original down to the oil bath air cleaner 1964 Corvette -All power A/C 327 4 spd. tanker |
10-27-2009, 01:41 PM | #15 |
After you power wash the frame, power wash the drive, unless it's not paved.
I knocked a lot of crud off mine with straight water while it was still a rolling chassis. Rolled it back in the shop and started in on the drive. After I was done I needed a good rinse too. Next step now that it's down to just bare frame will be a degreaser (I like the oven cleaner suggestion) and another power wash. |
10-27-2009, 01:58 PM | #16 |
I'm an idiot. I meant I can't get it out of the garage!! Sorry!
10-27-2009, 02:09 PM | #17 |
10-28-2009, 12:29 AM | #18 |
Doesn't oven cleaner eat up rubber hoses and such? I would be wary about using it around brake lines/ fuel lines until I could verify that it wouldn't eat through them......
10-28-2009, 07:50 AM | #19 |
cant yoy roll the truck in an out of the garage?
10-28-2009, 10:27 AM | #20 |
i could just see it now....
1972 chevy c 10 longbed 2000 Ford Powerstroke (daily driver) |
10-28-2009, 12:47 PM | #21 |
Load it up on a trailer and do it all at the car wash at about 2 am, leave the mess for them to clean up!
10-28-2009, 01:29 PM | #22 |
Suburban Hick
Been ther done that!
Mathew 1947 Chevy 3600 1951 GMC 100 1969 Chevy C-10 396/500hp TH400 lowered 4" 1968 Imapla Custom 396/325hp TH400 "Grandmas Car" 1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505 1978 Chevy K-10 454 1983 S10 4x4 "Bumblb" (Grandpa's truck) 1993 Chevy S10 V8 conversion 1990 Ford Probe Gt 1992 Dodge W-150 "Old Man's Truck" 1992 Pontiac Grand Prix SE 1992 Mercury Grand Marquis-Mercruiser 2000 Ford F150 (Currently my mother drives this) 1946 Farmall H with Stan Hoist loader 1965 John Deere 110 1961 Wheel Horse " Rat Tractor" |
10-28-2009, 02:28 PM | #23 |
Yep, thats gonna be the plan. The back I'm getting everything with sandpaper, wirewheels, and paint stripper pads. It's not that bad. But closer to the front, oven cleaner and then push her outside.
Thanks guys |
