Old 10-27-2009, 04:14 AM   #1
Shamil
Shamil's Avatar
292 engine problem
I’m facing problem with the engine, when I hit the gas to the end and release I hear a strange sound like (rererererererrererererererrerererererer)can some one help me to find out what is this sound, where is it come from.....
Shamil is offline   Reply With Quote
Old 10-27-2009, 10:47 AM   #2
MudBug
MudBug's Avatar
Re: 292 engine problem
manaul or automatic transmission and how old is the engine?
MudBug is offline   Reply With Quote
Old 10-28-2009, 01:19 AM   #3
Shamil
Shamil's Avatar
automatic th400 with NP208, i have no idea how old is the engine, the head is not integrated.
Old 10-28-2009, 02:25 AM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Where is the sound coming from? Can you make a better sound of it?
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 10-28-2009, 08:58 AM   #5
Shamil
Shamil's Avatar
the noise appear when i wide open the throttle and close it, the noise last few second 3-4 seconds till the engine calm, when opening the throttle slightly i do not hear that sound.
Old 10-28-2009, 11:33 AM   #6
manimal
manimal's Avatar
Does it happen when you turn the steering wheel? Do you have power steering? Check your tranny fluid also.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 10-28-2009, 04:07 PM   #7
gchemist
gchemist's Avatar
Check the u-joints.
Old 10-29-2009, 08:29 AM   #8
Shamil
Shamil's Avatar
thanks guys for the help.... i'll try everything on week end
Old 10-31-2009, 02:31 AM   #9
Shamil
Shamil's Avatar
yesterday i checked everything with a friend, we did not find any thing wrong. but my friend find the sound coming from harmonic balancer, when he removed it he find that the grove is damaged and need to replace the harmonic balancer.
what choices do i have for such balancer would the small V8 engine fits my engine?
it 292 parts are rarely to find, where i'm from
Old 10-31-2009, 11:55 AM   #10
dan76
Last time I was in your area, there were tons of Chevy sedans running around. Maybe it's time to drop a small block into your truck. Parts will be more available.
dan76 is offline   Reply With Quote
Old 11-02-2009, 01:30 PM   #11
Shamil
Shamil's Avatar
after removing the engine we find the problem. first problem is with the harmonic balancer was not set tight due to a crack in the center......
the second problem is with the flywheel, because the harmonic was not set tight it cause a vibration and that vibration affect on the screw on the flywheel and make them to lose......all fixed and i'm happy
