Old 10-27-2009, 06:23 AM   #1
vegaschevy
removing trailing arm crossmember
Is it possible without removing the cab on a SWB 2wd? seems you may be able to get the rivets out without to much work. Anyone done it? any tips?
vegaschevy is offline   Reply With Quote
Old 10-27-2009, 07:12 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: removing trailing arm crossmember
I plan on cutting the "center" of the old crossmember out (cutting at about 4"-6" from each end) with a sawzall.
Then just grind the rivets and remove what's left, without having to fight the whole thing.
Keith
Convert to disc brakes.
Old 10-27-2009, 07:39 AM   #3
dznucks
dznucks's Avatar
i just removed mine. i used a plasma cutter. sawzall will work, i guess. i made two cuts, to remove the center, leaving the four tabs still riveted on. I then used the plasma to blast off the rivet heads. then i used the tabs as leverage to yank the remaining portion of the rivets out.
dznucks is offline   Reply With Quote
Old 10-27-2009, 07:40 AM   #4
dznucks
dznucks's Avatar
Watch your fuel line!!!
Old 10-27-2009, 07:48 AM   #5
panhandler62
Java Mechanic
panhandler62's Avatar
I must have the "rivets from hell" because there has been nothing "easy" about knocking the vrivets out of any part of my frane. :P
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 10-27-2009, 07:53 AM   #6
lolife99
lolife99's Avatar
You guys with plasma cutters have it made.
I still have to grind the rivet
head and air chisel mine out.
Keith
Old 10-27-2009, 10:15 AM   #7
dznucks
dznucks's Avatar
I borrowed a plasma. it is worth it for the rivets alone.
You may look around in your area, you would be suprised at the number of places you can rent them for a resonable price. you'll need an air compressor for most of them though.
another thing that i found that helped are carbide drill bits. Fastenal has resonable prices on them. they are brittle and break easily. but if you use it nice and slow, making sure not to let it grab the metal, it will drill right through the rivets and frame.
another thing that helped was a 7/16's carbide reamer for opening up the holes that didnt line up or that got messed up with the plasma.
good luck, go ahead and put money in the cuss jar, its not going to be fun, but it will be worth it.
Old 10-27-2009, 10:38 AM   #8
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
Yea well my little 13 gallon craftsman compressor won't run my air chisel worth a poo. Hell it won't even power my impact enough to take the wheels off. I guess it's the old school way for me.
I've also found that if you grind the head off, then drill a hole a little smaller then the rivet, use as BFH and a punch it comes out easier.
Matt
'69 Chevy SWB Fleet, Primer Black; Project No Name
'06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold
'08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!!
'99 Dodge Dakota R/T, Intense Blue; DD, Sold
Originally Posted by longbed67 View Post
The tig welds are not the prettiest i have seen but they do have good penetration.
Originally Posted by oldblue1968chevy View Post
There are two things in life where penetration is really important.....and one of them is welding.
stealthy '69 is offline   Reply With Quote
Old 10-27-2009, 12:10 PM   #9
vegaschevy
every factory rivot i have ever taken off it seemed to work easier then a plasma to just air chisel the head off.....
Old 10-27-2009, 05:35 PM   #10
dwcsr
Hollister Road Co.
dwcsr's Avatar
If you can get a drill in there drill the rivet and bust off the head, then drive it out with a punch.
Center punch the rivet head. Use a 1/8" bit to drill a pilot hole past the jointed metal pieces. Then use a drill bit thats atleast 3/4 the size of the rivet past the 2 joint pieces of metal then bust off the head with a chisel, the rivet will collapse on itself when you drive it out. If you don't drill past the jointed pieces of metal it will take far more hammer force to drive it out.
dwcsr is offline   Reply With Quote
Old 10-27-2009, 07:00 PM   #11
SCOTI
SCOTI's Avatar
Good pro quality air chisel & tip = easy job. Older 'hand me down' air hammer & Home Depot tip = bring a sack lunch 'cause you'll be there a while (bring a cut-off wheel too 'cause you'll need it as well ).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-29-2009, 07:02 AM   #12
n2billet
Village Idiot....
n2billet's Avatar
This is what I used and it took me less than 20 minutes to knock it out (had to stop and get a drink) This is one of my favorite tools in the shop......ask Scoti, I use it for everything! Make sure and get good bits.....they cost almost as much as the hammer but make life easier.
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline   Reply With Quote
Old 10-29-2009, 03:21 PM   #13
cst350
cst350's Avatar
I rented a 35lb electric jack hammer from the local rental yard. Sharpened the 3" wide clay spade into a chisel. Nothing like a little leverage! A couple of the upper rivets still needed to be drilled out from the frame after the crossmember was removed. I got a long drill bit and went through the lower holes so as not to ovalize the frame holes.
cst350 is offline   Reply With Quote
Old 10-29-2009, 03:31 PM   #14
Hart_Rod
Hart_Rod's Avatar
I got a air chisel and bits at Lowes for $20. I'm sure it's not as nice as yours, but for the average guy it's not a bad way to go.
Hart_Rod is offline   Reply With Quote
Old 10-29-2009, 07:41 PM   #15
capev86
i used an air chisel to remove two rivets on the front crossmember to install the drop down brackets for the CPP sway bar on my 72 burb 3/4 ton. the frequent breaks to let the pump catch up allowed me to rest my arms.....tough lying on your back under the truck holding up a heavy impact gun. a portable tank is great if you don't do it every day....but i soo want a huge tank and a 5+ hp pump in the future when i have my (dream) garage/shop all set up. this winter my burb will have to sit out in the snow. i need to get a custom fit cover and a good tarp to go over it.
capev86 is offline   Reply With Quote
Old 10-30-2009, 09:22 AM   #16
Naterman35
It helps if your bit has a V in the center to...
When i was taking things off my frame i just got an air chisel and the bit had a V... Went extremely fast... I first tried a torch and it sucked for doing that.
Naterman35 is offline   Reply With Quote
Old 10-30-2009, 01:16 PM   #17
Damien
Damien's Avatar
I used my matco air chisel and a cheap bit to get sway bar mounts off. It took maybe 10 min. to get the four rivets out and a good hammer to knock the brackets off. Much much better the gringing the heads off and pounding rivets out.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
