Old 10-27-2009, 09:39 AM   #1
Chevyholic
Will it run today?
Chevyholic's Avatar
Smile I've Got Gas
Swapping out my fuel tank and unfortunately have about a half-tank of gas in the old one. What is the best method for emptying the original tank before removing it? I've got rust in the tank so will have to filter it, but can approach that issue later.
Any ideas?
Thanks!
Jaws, the 1971 Chevy Cheyenne Longbed.
She's big, grey, and has an insatiable appetite!
Chevyholic is offline   Reply With Quote
Old 10-27-2009, 09:41 AM   #2
msgross
msgross's Avatar
Re: I've Got Gas
piece of garden hose and a jug... little siphon action will get you going.
or leave the cap on, pull the tank (heavy now) and dump it...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 10-27-2009, 10:39 AM   #3
Sinister
Between Trucks...
Sinister's Avatar
Re: I've Got Gas
You can drain it from under the cab. There's a short piece of rubber fuel line that goes from the tank to the hardline.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 10-27-2009, 10:58 AM   #4
69GMCLonghorn
69GMCLonghorn's Avatar
Re: I've Got Gas
In terms of what to dispose of it in, most major cities have a haz mat retrieval program where they will give you 2 or 3 of those 5 gallon jugs. You fill them up and they come and pick them up. At least out here, that is how it works.
69GMCLonghorn is offline   Reply With Quote
Old 10-27-2009, 11:51 AM   #5
95light
95light's Avatar
Re: I've Got Gas
Just removed about 16 gallons from mine.
Step 1: Add 3/8's hose to the line coming out of the tank were the sending unit is wired up. Use enough hose to go to a 5 gal. gas can.
Step 2: Turn your compressor down to about 40-50 psi and attach an air nozzle to it. Use a shop towel and ball it up into the fuel fill along with the end of the air nozzle.
Step 3: Add compressed air and watch the jug fill up.
It's the quickest and best non-tasting way I found.
95light is offline   Reply With Quote
Old 10-27-2009, 12:03 PM   #6
69GMCLonghorn
Re: I've Got Gas
You just took 16 gallons out of it? So in other words, it was full?? Why didn't you drive it until it was on fumes, then drain it?
Old 10-27-2009, 01:04 PM   #7
95light
95light's Avatar
Re: I've Got Gas
After just buying the truck the truck I filled it up on the way home and started sorting out a few problems (minor ones). One of the problems was it pinged pretty bad so after going though all the checks I happened to put a clear fuel filter on and noticed when I started it up again the fuel was orange with rust chips. Tank looked almost new on the outside but the inside was another story.
Old 10-27-2009, 01:55 PM   #8
KrazyRay
KrazyRay's Avatar
Re: I've Got Gas
I rigged up an in line fuel pump with some fuel line and a battery. I put the old gas in a jeep can and use it up on my ranch truck. It does not run very good but I never have to buy gas for it. If the gas is really bad, it goes in to my New Years bon fire.
KrazyRay is offline   Reply With Quote
Old 10-27-2009, 07:10 PM   #9
truckdude239
truckdude239's Avatar
Re: I've Got Gas
u can always use it in your lawn motors
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 10-27-2009, 08:02 PM   #10
72lb4x4
Re: I've Got Gas
You can siphon by using some extra length hose, pushing it into the tank most of the way, covering the end with a thumb and then pulling it out part way.
72lb4x4 is offline   Reply With Quote
Old 10-27-2009, 08:36 PM   #11
msgross
msgross's Avatar
Re: I've Got Gas
that's not a straight drain though, it goes up to the top and in through the sending unit... Combine that with the air compressor method sounds like a good plan.
The Garage:
Old 10-27-2009, 10:25 PM   #12
RustyBucket
RustyBucket's Avatar
Re: I've Got Gas
look on the Bass Pro/Outdoor World site.... use "SAFETY SIPHON" for a search. WORKS GREAT!! haven't had a drink of gas in several years
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 10-28-2009, 12:15 AM   #13
2tons of fun
Re: I've Got Gas
open the cap and setup you welder next to it, stand back and plug in te welder.
2tons of fun is offline   Reply With Quote
