california stock exhaust
anyone know the stock configuration of an exhaust system for an 81' C10 short bed with a 350 and standard transmission? i have to visit the CA DMV referee for my engine swap and want to make sure my exhaust is good to go, especially with all the new 2009 cat laws around here.
1981 C10 SWB 350 (in progress) 3 on the Tree "Old Bess" 1996 K3500 Crew Cab 454 4L80E "Family Camper" 2002 GMC 1500 Yukon XL 4WD "Wife's Ride" |
78 Big10 454
![]() Join Date: Jul 2008
Re: california stock exhaust
I'm not sure of your configuration, but I'd stop by a muffler shop and see if they can look it up for you. They use a manual that shows the stock exhaust set-ups for all vehicles originally equipped with cats. Worth a try.
The muffler shop I use has two manuals with conflicting info, one says two cats and the other says one, ain't that a shocker. Hoping someone on here remembers their 81' before they started wrenching on it!
1 cat. if you look under your truck you should see where the frame rail on the drivers side was bent to fit the large old school cat in there between the tranny and frame. thats how my '78 and '85 k5 were. 1 cat... smog tube manifolds to a y-pipe to the cat out to a muffler.
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list
78 Big10 454
Mine was set up the same exact way with one cat wying off to two mufflers/tailpipes. I subsequently changed over to two cats/mufflers in 1980 and have never had a problem with passing smog.
Thanks! Confirmed y-pipe to one cat. I hope to go to duals as well, but since I have to visit the CA DMV referee for the engine swap and there are some stringent cat laws effective this year, I figure I would go stock for now. Thanks for the input!
78 Big10 454
We are at your service!
dude i am in san diego and swapped out a for a 350 bored .60 over extreme comp cam forged pistons, posi rear 4:11 gears....650 holley carb..then headers straight to cherry bombs thats it ..wo cares california can suck my balls.....keep your stuff registered in another state
if your military
DON'T TREAD ON ME ACTIVE US NAVY just a 19 year old kid putting together a winner |
>130dB Moderator
For those of us who aren't signed up though...
There aren't any new laws pertaining to cats or the quipment in general. They have been the same for a long time. You need the OEM equipment from the donor car/motor or an OEM equivlent. Thy will allow you to run newer style cats and such, but you are not allowed to eliminate any equipment from the system and the ref. knows how to check if its in working order, so don't try and slip past him either.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
Squarebody Aficionado
lmao, its like the man kickin it to the man!
in cali you guys cant run aftermarket straight thru high flow cats? damn that sucks.
#13 |
Its done for now. I went stock 2.5 with custom collectors and y pipe into 2.5 oem style cat into single 3" out the side. I get to visit the referee next month and get my sticker for a CA legal motor swap. I have been driving the truck for the past two weeks to work and really love it! It moves without effort and sounds great.
#14 |
I had an '81 K5 Blazer that was all stock. The exhaust manifolds came together at a "Y" then exited through one cat-back and one exhaust pipe. my '76 1/2ton had true dual exhaust with no cat backs and only A.I.R. fittings on the exhaust manifolds. both were California vehicles
#15 |
Cruzzzn' Vet
#16 | |
No No
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
| Bookmarks |
