10-27-2009, 07:07 PM | #1 |
fuel injection wiring harnesses
Having put in a few late model fuel injection motors I know that trying to save money on a wiring harness will come back to bite you in the can. So I will not be trying to salvage a stock harness. My question is where are you boys getting your wiring harnesses for the 4.8 5.3 and 6.0 liter engines? I've found a place online that you can pick up a harness to controll the motor and a 4l60e for a touch over 600 dollars. Anyone found any cheaper?
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
10-27-2009, 07:59 PM | #2 | |
Re: fuel injection wiring harnesses
http://cgi.ebay.com/ebaymotors/1999-...Q5fAccessories Just STAY AWAY from anyone from New York named Jeff Roberts or East Coast Engines. Guy ran a scam where he took your money and harness to do a rewire and then you never hear from him again. He got me and LOTS of other people. If I didn't live so far from New York... |
10-27-2009, 08:04 PM | #3 |
I reworked the harness that came with my 5.3 cost was 0$. The only cost will be the reprogramming of the pcm. I found if you take your time its not that hard to do.
Jean-Marc Lacasse 57 GMC 55 GMC 55 Belair 99 S10 http://67-72chevytrucks.com/vboard/s...d.php?t=316140 http://67-72chevytrucks.com/vboard/s...d.php?t=806011 |
10-27-2009, 08:08 PM | #4 | |
10-27-2009, 08:16 PM | #5 |
my motor is out of a 05. i've only seen em up to 04's?? what gives. also mine is a wire throttle instead of cable
10-27-2009, 09:14 PM | #6 | |
Hollister Road Co.
http://www.moparstyle.com/forums/showthread.php?p=62407 Also look at pirtaes 4x4 site. |
10-27-2009, 09:27 PM | #7 | |
10-27-2009, 09:38 PM | #8 | |
http://howellefi.com/customer/produc...cat=325&page=1 You could get a cable operated throttle body and convert but that might get the price back up. If you decide to do the DBW harness be sure to get the gas pedal out of the donor truck...you'll need it. |
10-27-2009, 10:05 PM | #9 |
10-27-2009, 10:16 PM | #10 |
http://ls1wiringharness.com/
the one i was looking at is this guy. ill go get back on ls1tech and see what i can dig up
10-28-2009, 12:18 AM | #11 |
Tripple Five Fanatic
I used this guy for my harness and tune, good price and he knows what he's doing.
http://wait4meperformance.com/ |
10-28-2009, 07:04 AM | #12 | |
1971 Corvette convertible 454@ 525 hp 1936 Chevy Truck street rod 1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up 1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html 1950 custom Chevy Truck |
10-28-2009, 11:06 AM | #13 |
A320 Pilot/USAF Retired
Here's another source, a bit pricey but they do have a DIY conversion harness, something I've not seen before.
http://stores.ez2wire.com/-strse-Cur...Categories.bok
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
10-28-2009, 08:54 PM | #14 |
well whats up dudes?
Ive got a 5.3 in my 50 model AD.I reworked the factory harness and sent the computer off to lt1swap.com . My truck runs great!! Also lt1swap.com has a great web site shows how to modify harness and he will reprogramm ecm for 75.00 dollars. |
10-28-2009, 10:28 PM | #15 |
Reworked my original Impala SS harness with a friend who happens to be a GM electrician. He also reprogrammed my ECM with his lap top
10-29-2009, 10:08 AM | #16 | |
That is some great info....I am about to redo my harness in about a week, so this will come in handy. Thanks Last edited by ambryatim; 10-29-2009 at 10:08 AM. |
11-15-2009, 06:17 PM | #17 |
I've got a 4.3 in my 49. I sent my motor and trans harness along with the pcm to Larry's Electric. He did a great job! Truck runs and shifts like it's supposed to. $500 if I remember right. http://www.larryselectricsite.com
11-15-2009, 07:04 PM | #18 | |
