Old 10-27-2009, 07:15 PM   #1
bigdon-70blazer
Emblems and badges restoration
Anybody remember if there are any threads about how to paint the black letters and such on our emblems? I searched but did not have time to sit for hours looking thought one of you may remember. I am trying to freshen up the Blazer emblems and the "4 wheel drive" badge form it's faded past.
bigdon-70blazer is offline   Reply With Quote
Old 10-27-2009, 07:27 PM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: Emblems and badges restoration
Here is a very quick way to help you out. Clean your emblems very well with soap and water with a brush. Get you some black laquer spray paint. Then, spray the emblem unmasked. Then after the paint drys, wipe the chrome edges off with a rag soaked in laquer thinner, and for corners and hard to rich spots, get out q-tips with laquer thinner. Hope this helps, Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 10-27-2009, 07:30 PM   #3
71blksuper4x4
SWB 4x4 Collector
It would be better yet, if you used a q-tip with a touch of 400 grit sandpaper around it and sand in the letter a little bit before cleaning. That way your paint has something to bite onto the chrome. Then to shine up your emblems, I use steel wool and windex lightly rubbing the surface. Really works to get tarnish off of chrome, but do that after your paint has fully dried as steel wool will leave bits of it's self until you wash it off. Trevor
TREVOR
Old 10-27-2009, 11:56 PM   #4
JJanzen
JJanzen's Avatar
I get the piece all cleaned up, then put it on a level surface. I then drop in lacquer thinner so that the entire bottom(area to be painted) is "wet". Then, take an eyedropper and fill it with "unthinned" enamel paint, drop it into the wet lacquer thinner and watch it spread out to where you want it to fill. The lacquer thinner then evaporates off and your are left with a perfect fill and no paint on the interior sides of the emblem....just the bottom where you want it.
Blue72
Red72
JJanzen is offline   Reply With Quote
Old 10-28-2009, 12:03 AM   #5
71blksuper4x4
SWB 4x4 Collector
Joel, do you use scale model paint? or like Rustoleum pint paint?
TREVOR
Old 10-28-2009, 12:11 AM   #6
JJanzen
JJanzen's Avatar
I have used both your garden variety enamels you find at the hardware store but my favorite is One Shot Bulletin Enamel. It comes in a wider variety of colors. It is the same paint that oldtime sign painters use and can be found at some automotive paint suppliers and sign material distributors. Here is their website:
http://www.1shot.com/home.html
Blue72
Red72
Old 10-28-2009, 12:14 AM   #7
'68 C-20
'68 C-20's Avatar
JJanzen,
awesome idea. It would work well for restoring the old wheel covers as well!
DIY body and paint work is cheap, making it look good... priceless
My Toys;
’26 Ford Model T
‘72 Triumph Spitfire 1500
'09 "The Briggs Flyer" Gettin' High.
'68 C-20 is offline   Reply With Quote
Old 10-28-2009, 12:22 AM   #8
dan42
dan42's Avatar
Ditto that - killer idea. I have always wondered what the best way to do that is. Thanks for the input.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 10-28-2009, 12:46 AM   #9
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Awesome idea JJanzen!
Filed that one away for future reference...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 10-28-2009, 08:25 AM   #10
'68 C-20
'68 C-20's Avatar
Are you refering to model paint or 1/2 pints of enamal? I would like to play with this a bit before I order the good stuff.
I see the one shot is owned by Spraylat, they make a pretty good line of customer Powders.
My Toys;
’26 Ford Model T
Old 10-28-2009, 08:42 AM   #11
JJanzen
JJanzen's Avatar
I think any enamel (suitable for exterior use) would work. My only concern about model paint is its' durability in an exterior application. The exterior enamels will have UV inhibitors that will keep it from fading and I don't know if model paints have that. If you have to thin it to get it to flow, use lacquer thinner, it will evaporate off the fastest. Also, I don't know how long this has been a Spraylat product...One Shot has been around for about 50 years or more. Like anything, you will have to play around with it to get it to work perfectly. Good luck.
Blue72
Red72
Old 10-28-2009, 04:00 PM   #12
bigdon-70blazer
Got the stuff and I am going to try it tomorrow! Thanks!
Old 10-28-2009, 05:04 PM   #13
71blksuper4x4
SWB 4x4 Collector
Don, did you get a semi-gloss/Satin black??? Gloss will be to shiny and flat is really really dull. Trevor
TREVOR
Old 10-28-2009, 05:20 PM   #14
rambler
MOVE OVER
rambler's Avatar
subscribing to this post, and hoping for pics later of your progress!
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 10-28-2009, 05:48 PM   #15
tcb-1
Nothing to see here.....
tcb-1's Avatar
too bad we can't give rep points jjanzen, you'd receive some from me!
post up some progress pics on the emblems, big bro.....
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 10-28-2009, 10:24 PM   #16
'68 C-20
'68 C-20's Avatar
Will be monitorin' please post pics as soon as you can. I want to use this process on my hubcaps.
My Toys;
’26 Ford Model T
Old 10-28-2009, 11:39 PM   #17
bigdon-70blazer
They don't sell laquer paint anymore but I did find some in a spray can that I am going to try and I will post pics due to all the interest in this subject. Wish me luck, I'm going in!!!
Old 10-28-2009, 11:40 PM   #18
bigdon-70blazer
I got gloss black because the area is so small...
Old 10-29-2009, 08:23 AM   #19
'68 C-20
'68 C-20's Avatar
Experiment with it on a scrap piece but I have found that a little Toluene available at all hardware stores will dull down the gloss a little. I stumbled upon it when I used a brush cleaned in it when I changed colors while painting steel patio furnature. I noticed that area that I started with was duller then the end I finished with. Then the light dawned and I realized my brush was still wet from the Toluene when I started to paint.
by itself It evaporates quickly and might just work as well as the Lacquer Thinner on enamel paints.
My Toys;
’26 Ford Model T
Old 10-29-2009, 10:45 AM   #20
JJanzen
JJanzen's Avatar
Don,
I don't think you want to use lacquer paint. It flashes too quickly and won't have a chance to settle in the piece like an oil based enamel. I think you could use any thinner that evaporates quickly....my preference is lacquer thinner because I always have it around.
Blue72
Red72
Old 10-29-2009, 11:26 AM   #21
71blksuper4x4
SWB 4x4 Collector
I prefer lacquer paint as that would be what the factory used and I think it adheres to the chrome better than enamel, though it might take a few extra coats.
TREVOR
Old 10-29-2009, 12:21 PM   #22
100gold
Good ideas here. I shipped my woodgrain door inserts and glove box door down to the Terrys in Abilene and slipped all my emblems and the hvac chrome slider face in the box at the last minute.
His price for restoring my emblems was very reasonable. I want to say it was about 10.00 per if I remember right. They should be back today or tomorrow and I could post some pics if you're interested.
100gold is offline   Reply With Quote
Old 10-29-2009, 07:20 PM   #23
gcburdic
Restoration Virgin!
gcburdic's Avatar
Good stuff!!...Thanks Guys!!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 10-29-2009, 10:24 PM   #24
bigdon-70blazer
Interested!
Old 10-29-2009, 10:38 PM   #25
bigdon-70blazer
Well, I did it and they turned out fine! Used some acrylic laquer gloss spray paint, a syringe and needle, if you can believe that. Sprayed the paint in a container so I could draw some up into the syringe. Then I placed the emblems on a level surface, poked holes in a box and mounted them there then filled up the letters and lines with paint from the syringe. Easy! Let dry and mount. Don't know how long it will last but looks pretty good I think!
