Old 10-27-2009, 07:39 PM   #1
gus
06' Silverado SS Rear-end (Diff.) swap.
has anyone done this swap on a 70-72 2WD Blazer or 67-72 C10?
I have this rearend, it came off from my motor donor truck , its an 06' Silverado SS model, the rearend differential its a 2WD w/drum brakes !
gus is offline   Reply With Quote
Old 10-27-2009, 09:06 PM   #2
Critter
Future TOTM Winner
Critter's Avatar
Re: 06' Silverado SS Rear-end (Diff.) swap.
I have seen some of those trucks with the 14 bolt semi-floating axle and some have the regular 1/2 ton 10 bolt axle. Just curious which one you have?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 10-28-2009, 06:53 AM   #3
vtblazer
vtblazer's Avatar
I ran a '98 14bff in my blazer.
vtblazer is offline   Reply With Quote
Old 10-29-2009, 06:17 PM   #4
gus
Critter:
my rearend came off of an 06' SS Silverado 2WD with drum brakes and its a 14Bolt, anyone has the specs. of this particular rearend (differential)?
is it possible to swap it to my 2wd K5?
thanks.
Old 10-29-2009, 06:52 PM   #5
vtblazer
vtblazer's Avatar
Originally Posted by gus View Post
Critter:
thanks.
Why not just break out a tape measure and measure the perches, width ...etc?
Old 10-29-2009, 07:01 PM   #6
1lowdiesel
1lowdiesel's Avatar
i know that rear is a direct swap into a 98 body style but not sure on the older ones. most likely it's a 3.73 rear.
also that truck is AWD
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 10-29-2009, 07:26 PM   #7
Critter
Future TOTM Winner
Critter's Avatar
and I will tell you now, it won't bolt right in. The spring perches are at a different width plus your u-joints aren't the same. It isn't hard to make it fit though, weld on some new spring perches and get an "adapter" ujoint and you are good to go.
