Old 10-27-2009, 09:47 PM   #1
bigt76_98
Blazer frame for truck???
i couldnt really find any info searching for this, so ok this guy i know says he has a 4x4 72 blazer frame and he want to sell it minus the engine and trans for fairly cheap for a 4x4. any way can i make a pickup out of it? and or how much fab would be needed? also is there anyway i can tell its for sure a 72 blazer frame? thanks a bunch
bigt76_98 is offline   Reply With Quote
Old 10-27-2009, 09:57 PM   #2
bigt76_98
Re: Blazer frame for turck???
oops TRUCK !
Old 10-27-2009, 10:47 PM   #3
BIGBLU 72
BIGBLU 72's Avatar
A guy i know put a truck out of a Blazer frame by cutting down the bed. i dnt know any technical stuff or how hard it was but i do know that i can be done and looks sweet!
68 C10 LWB 2/4 drop 406/th400/3.73posi
04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD
BIGBLU 72 is offline   Reply With Quote
Old 10-28-2009, 07:30 AM   #4
bigt76_98
Re: Blazer frame for truck???
well he was wanting to trade some parts for this frame so i was just wondering if it was worth it to get it
Old 10-28-2009, 12:17 PM   #5
71tahoe
71tahoe's Avatar
A 71-72 will have front disc brakes, others will have drums.
Short wheelbase is 115" and I think the blazer is 105".
71tahoe is offline   Reply With Quote
Old 10-28-2009, 12:57 PM   #6
UltraBlue71
UltraBlue71's Avatar
I know of one of these running around town out here, If I can run him down I'll try to get the skinny on it, Its a 4WD with a 4-6in lift dark green/white, really sharp looking. He used the Blazer rear quarters to make his super shortbed, so it has the gas filler in the same place as a Blazer but it has an actual bed and cab on it, if I am making any sense...
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG...
71 LWB
UltraBlue71 is offline   Reply With Quote
Old 10-28-2009, 01:14 PM   #7
lks dcvn
lks dcvn's Avatar
blazer wheelbase = 104
lks dcvn is offline   Reply With Quote
Old 10-28-2009, 01:25 PM   #8
brothers69c-10
Suburban Hick
brothers69c-10's Avatar
My cousin built a 4x4 long box frame out of rear leaf spring 2wd frame and the front half of the blazer frame. I think he basically sectioned it where approximatley the middle of the cab would be. Hopefully someon will chime in on this, but i think the front blazer body mounts are in the same location as the front cab mounts on a truck.
Mathew
1947 Chevy 3600
1951 GMC 100
1969 Chevy C-10 396/500hp TH400 lowered 4"
1968 Imapla Custom 396/325hp TH400 "Grandmas Car"
1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505
1978 Chevy K-10 454
1983 S10 4x4 "Bumblb" (Grandpa's truck)
1993 Chevy S10 V8 conversion
1990 Ford Probe Gt
1992 Dodge W-150 "Old Man's Truck"
1992 Pontiac Grand Prix SE
1992 Mercury Grand Marquis-Mercruiser
2000 Ford F150 (Currently my mother drives this)
1946 Farmall H with Stan Hoist loader
1965 John Deere 110
1961 Wheel Horse " Rat Tractor"
brothers69c-10 is offline   Reply With Quote
Old 10-28-2009, 02:49 PM   #9
UltraBlue71
So I guess you would wind up with a 5 foot 2 in bed? Using a blazer chassis? But wait the body bushing location wouldnt line up would they?
71 LWB
Old 10-28-2009, 07:38 PM   #10
JimKshortstep4x4
I made a plow using a Blazer frame. I installed rear cab mounts so the cab could be bolted to the frame and made a home made bed out of oak boards. It is really short but I need something short for plowing around my buildings.
Here is a picture of it.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 10-29-2009, 10:10 AM   #11
UltraBlue71
Thats a cool little bobtail! Does it work good for ya? I bet you have to put a bunch of weight on that little flatbed huh?
71 LWB
Old 10-29-2009, 10:20 AM   #12
monte0185
monte0185's Avatar
If you lengthen the frame you should have any problems and I would think that would be alot easier that shortening everything else.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 10-29-2009, 10:33 AM   #13
71tahoe
71tahoe's Avatar
Depends on what you're comfortable with.
Lengthen the frame:
Weld a section to an integral structural part of the vehicle.
Lengthen the brake lines.
Lengthen the e-brake cable.
Lengthen the fuel lines.
New longer driveshaft.
Shorten the bed:
Cut a section and re-weld bedsides and floor.
Body work and paint.
Old 10-29-2009, 10:52 PM   #14
pritch
pritch's Avatar
I built this one out of a bunch of spare parts I had laying around in about '82 or so. This is the only picture of it that has survived. I drove it for years, this picture was taken at our local demo derby of '87. At least that's what it says on the back of the picture.
I never had the time or money to do all I wanted to it. It is a '67 cab on a '71 Blazer frame, with lots and lots of mis-matched JY bed parts. I had a nice wood flat bed on it before I built the step side. We cut the about 10" out of the middle of the bedsides, figuring that there would show the least amount of amature welding.
As far as mounting the cab, the body mount for the Blazer was exactly where it needed to be to mount the back of the cab to, but that's not strong enough and the back of the cab sagged some over the years. I think with just a little bit of re-enforcment of that mount would have solved the problem. It was a fun little truck and got a lot of second looks. I wish I hadn't sold it, but at the time I needed the money. Maybe someday I'll do another.
That's me in the back in the light blue shirt, my 2 sons @ 3 and 6, and my wife with the big blond 80's hair
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 10-30-2009, 12:24 AM   #15
bigt76_98
so ya i guess i could do some cool stuff with it if i got it but it wouldn't be bad since he is wanting to trade anyway and it wouldnt take any money for my other projects for now, god knows i have enough and i almost have the 69 on the road
