Old 10-27-2009, 10:33 PM   #1
'68 C-20
'68 C-20's Avatar
Carb Swap
I Picked up a '67 for a yard truck this week. 292 with a model B Rochester Carb. It is running rough and I have dealt with the usual starting points, compression, timing, plugs, wire, cap, points, set the dwell, etc.
So I am pretty sure the Carb needs a rebuild.
That being said, my '68 has a 296 with a Rochester M on it. The '68 runs real smooth. As far as the Base of the Carb is concerned are they interchangeable as far as the manifold is concerned?
I figgerd'' I would pull the Carb off the '68 to see if that would solve the rough running.
DIY body and paint work is cheap, making it look good... priceless
My Toys;
’26 Ford Model T
‘72 Triumph Spitfire 1500
'09 "The Briggs Flyer" Gettin' High.
'68 C-20 is offline   Reply With Quote
Old 10-27-2009, 11:04 PM   #2
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: Carb Swap
it will be the same.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 10-27-2009, 11:21 PM   #3
'68 C-20
'68 C-20's Avatar
Re: Carb Swap
Great, Thanks!
My Toys;
’26 Ford Model T
