67-68 hood and grill mating to 72 gmc fenders??
I am wanting to mate a 67-68 hood and grill to 72 gmc fenders will this work? I read the tech site on the home page of this site and it says it will does anyone else know for sure???
bogey5 |
So Many Ideas, So Little Money
it should, the 68-72 GMC fenders are supposed to be the same as 68 Chevy fenders..
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu ![]() Marshalltown, Iowa |
Yes, I put a 67-68 chev grill & hood on a 72 GMC the fenders fit fine. I would recommend putting the 67-68 chev core support in. I tried converting the 72 GMC core support by changing the headlight bucket and it turned into a total pain in the ass and turned out half assed. The "base core support was different even though it looked the same.
Marysville, WA (Dan72cst@hotmail.com) 72 4wd Blazer CST 350/350 72 4wd Chevy LWB 350/350 68 2wd Chevy LWB 327/400 |
thank you I plan on changing the core I ve been told it was a b*&^h to convert I appreciate your answers.
bogey5 |
What is the difference from the 67/68 GMC core support vs the 69/72 core support?
This is only my opinion and it is subject to change. 70 GMC Short box stepside Blown 388 Stroker 72 K/5 Blazer 350/SM465/205 |
chaptr2
I can't answer your question....I thought GMC core supports would interchange from 67-72. I made a 72 GMC core support work for a 67-68 chev grill. I knocked the GMC headlight buckets off, but the big hole behind them was in a different spot than the 67-68 chev. I ended up cutting an even bigger hole that looked terrible. You also have to do some drilling and fabbing square holes for the headlight adjustment screws and drill holes for your gravel pan. I think the wiring plugs were in a different spot as well. The general size was the same, but I wasn't happy with the final product.
