Old 10-28-2009, 08:25 AM   #1
mainermikeyd
mainermikeyd's Avatar
Carb spacer or not
Are you guys running a spacer on your carbs or not?? Edelbrok 1405, with a performer intake, been reading alot an the popular myth orf running a spacer doesn't necessarily mean power gains, whats your opinion??
Once a Marine Always a Marine OOH-RAH
GM Fanatic
1982 K20 4" Rancho lift 350cid, edelbrock performer intake 1405 carb, hedman headers, TH350, " Wheres the MUD!!!!!!!!!!"
1986 c30 camper special 454, th400 (for sale)
1984 K10 Big Ten (project) needs motor
1984 C10 355, 700r4, (project) needs shortbox bed
mainermikeyd is offline   Reply With Quote
Old 10-28-2009, 08:46 AM   #2
68 TT
Still plays with trucks
68 TT's Avatar
Re: Carb spacer or not
Every engine & vehicle responds differently to what the spacer does so the only way to know for sure is trial & error.
68 TT is offline   Reply With Quote
Old 10-28-2009, 12:12 PM   #3
knockretard
I am running one to defeat my fuel boiling issue.My edel 1406 would heat up and boil the fuel causing a hard start if I tried to restart soon after. My 1" spacer cured the problem.
knockretard is offline   Reply With Quote
Old 10-28-2009, 01:17 PM   #4
billnorman
I see you are in Maine. Wait until summer to space the carb up to prevent icing.
billnorman is offline   Reply With Quote
Old 10-28-2009, 01:29 PM   #5
Mr.Scary
Project Optimus Prime
Mr.Scary's Avatar
I dont know about the myths or wut not or whether or not they provide HP gains, but I they are pretty cheap and most everyone that Ive ever known runs them and so do i. Like 68 TT said trial and error but I would run one just 4 kicks n e way!!
84 SWB work in progress
89 burb 1500 (parts pig) LOL
08 ford focus (I know, I know) Wifes car
"I said it b4 and i'll say it agian wiring is my worst enemy":devil:
Mr.Scary is offline   Reply With Quote
Old 10-28-2009, 01:50 PM   #6
68 TT
68 TT's Avatar
Try one of the 4-hole stacked plate heat shield type ones instead of a plain spacer.
The thermal break will make a real world improvement and the 4-hole design will not mess with the dual plane design of your intake and move your power band like an open spacer would.
http://www.summitracing.com/parts/MRG-3710/?image=large
This is what I have on my truck and have used them on everything I have built over the years. It has always made a noticeable improvement when the engine is warmed up where before the heat shield the carb would have been heat soaked. Keeping the fuel cool is always good.
Old 10-28-2009, 02:17 PM   #7
asphaltburner
asphaltburner's Avatar
Yo! mainermikeyd!
2" underneath FRANKENTRUCKs' 600 Holley and a 1" below my '76 Camaros' 625 Carter AFB (couldn't fit anything taller, even with the cowl induction hood! My '68 Mustangs' 302 has a 1", but nobody wants to hear that here!).
The best reason to use a spacer is to reduce heat soak from the manifold, allowing a cooler fuel intake and helping to avoid vapor lock.
A carb spacer does not increase power, but it does increase low end torque (slightly),...a high rise manifold is the proper item to take advantage of this effect.
And they're cheap!
I've never experienced icing, despite very low temps, but I'm in Colorado and our humidity is generally lower than most folks.
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
Old 10-28-2009, 10:00 PM   #8
slugish
Slugish
hAVE A 1/2 IN WOODEN SPACER ON MY 400. aLSO HAVE A AIRGAP MANIFOLD __ think the 1/2 in wooden really helped > before had a 2 in plastic spacer wkhich I feel was too much > lost torque . But I agree with some of the others-- too many variables involved to say which one will help you the most . Just have to try & see what happens
slugish is offline   Reply With Quote
Old 10-29-2009, 12:52 AM   #9
piecesparts
Parts and more parts
piecesparts's Avatar
I put an Edelbrock phenolic spacer under my AVS carb, to keep the heat off of the carb bowls. I have a 383 stroker motor in my 84 GMC. It sure helped and the engine runs fine with it.
Frank
piecesparts is offline   Reply With Quote
Old 10-29-2009, 11:40 AM   #10
McSwine
McSwine's Avatar
Would you mind telling me where you got your spacer? I have EXACTLY the same problem.
McSwine is offline   Reply With Quote
Old 10-29-2009, 12:06 PM   #11
68 TT
68 TT's Avatar
Check post #6 above. It is a combination heat shield and carb spacer all in one.
Old 10-29-2009, 12:07 PM   #12
von guido
von guido's Avatar
on a stret motor put a 4 hole phenolic spacer on. On race motors, i have seen a wilson open 2" spacer give an extra 15 hp on the dyno.
von guido is offline   Reply With Quote
