Watch out for your cornhole !
![]() Join Date: Jun 2003
Original 72 model small block engine accesories
Original 350 out of a 72 model truck. I only want to keep the longblock. Selling everything external from the engine.
Right exhaust manifold is bad. Carburetor, 50 plus shipping Spark plug wire brackets, 25 shipped Coil bracket 10 shipped Accelerator cable bracket 12 shipped If anyone is interested in any other parts shown, speak up and I will price it here. ![]()
Re: Original 72 model small block engine accesories
Are these the brackets that help kind of hide the wires by wrapping down the back of the engine then over the the plugs. (I know very bad description)
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together) Last edited by Primered_69; 10-28-2009 at 02:42 PM. |
I would be interested in the spark plug wire brackets, if you would throw in the metal down pipe that connect to the bottom of the breather and the piece it connects to on the manifold. Thanks Bill
Primered, that's the ones. I can go remove them later this afternoon to get better pics. I will put you first in line since you asked first.
Billyecapps, can't do that deal. I will have to sell the heat tube for another 20.
If Primered 69 passes, I would be interested in the plug wire holders and the heat tube, if that includes the other metal cover it attaches to on the manifold and it is in good shape, for $45.00 shipped.
Thanks, Bill |
Very good, let me see what Primered wants to do. You're second in line for the wire looms and 1st for the heat riser. I will keep you updated.
![]() Join Date: Nov 2002
carb good enough for a daily driver? can you tell me the #'s off of the carb?
If I can still use them with an aftermarket manifold I will take them
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together) |
Primered has spoken for the wire looms.
Billyecaps, since the wire looms have sold, I can't combine shipping on the heat tube and looms. I'd have to get 25 for the tube and manifold cover, delivered. Are you interested still, at that price ? 67sss, it was a decent runner about 6 months ago. Since removal, the engine has been sitting in my shop as you see it. I will get your carb numbers and post them up today.
![]() Join Date: Aug 2009
if 67sss passes put me in line, but will also need the carb number
72 Chev Cheyenne Super SB 4x4 350,4spd,buckets, tilt,tach,am-fm,extreme tow hooks,Canadian Model Production 1 of 52 SOLD 70 Chev CST, 350 auto, PS, PB, AC, tach |
Driller, you're second in line on the carb.
Numbers are: 7043202 J2 @ F8 ![]() ![]()
One of the First
![]() Join Date: Jan 2000
Looking at the timing cover and tab, plus oil pan with all hardware. Price and shipping to 32084. Thanks
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
#13 | |
Please pm me, I would like to pay with a postal money order, if possible. Thanks, Bill |
#14 |
billyecapps, here are the pictures of the parts. There are three pieces, the tube, and two halves of the manifold cover.
![]() ![]() I will PM you with my address.
#15 |
![]() Join Date: Jan 2007
kevin interested in fuel line from carb to fuel pump if it is not chewed on to bad shipped to 19320 thanks jim
#16 |
Jimer1964, I'm at work today. I will look at it tomorrow and let you know on the fuel line.
Heat riser set is sold to Billy Capps. Primered 69 has the wire looms D Passmore, I want to keep the pan and timing cover right now. I don't know how long this engine will sit before I build it so I want to keep it oil tight and bug free.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 10-30-2009 at 03:13 PM. |
#17 |
thanks for the #'s, I'm going to have to pass.
#18 |
valve covers if they are not dented. Temp sending unit if for gauges, engine hoist hooks driver front and pass rear.
#19 |
carb is wrong number for me Thanks
#20 |
Retired from a track near you!
![]() Join Date: Feb 2010
TX, Manifold cover, minus the tube, if billyecapps doesn't take it, to 37049 ? Also, steel tube, to vac. advance on distributor ? Thanks
#21 |
How far from Dallas are you? I may be interested in the carb.
