10-28-2009, 05:25 PM | #1 |
runnig lights w/headlights on
Somewhere I have seen a post that describes how to wire the running lights to stay on with the headlights. Does anyone remember where it is? Thanks
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
10-28-2009, 06:10 PM | #2 |
Re: runnig lights w/headlights on
are your doing is connecting the taillight output wire to the parklight output wire... #4 and #7 posts on your headlight switch. If your wiring is original, should be purple and brown like in this pic (not my pic).
http://www.6066gmcguy.org/lighting/6...switch-pic.jpg http://www.6066gmcguy.org/parklamp6466.htm I didn't have a fancy connector like in the pic so I just doubled them up in a butt connector. Last edited by 19GMC63; 10-28-2009 at 06:13 PM. |
10-28-2009, 06:33 PM | #3 |
Or you can do it like I did
http://67-72chevytrucks.com/vboard/s...hlight=PARKING
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
10-28-2009, 09:55 PM | #4 |
This exactly what I was looking for, once again somebody comes through with the answer.
10-29-2009, 12:08 AM | #5 |
Here is what I did. I remember doing this to my first truck in 1981...a '65 Chevy C10. Man, it looked cool at night.
10-29-2009, 11:08 AM | #6 |
Hey Tony what type of jumper is that?
10-29-2009, 11:53 PM | #7 |
60-66 Nut
A little tip if you're using a Scotchlok to do this. Take a knife and trim out the little wire stop on the one side. These are designed for splicing a new wire into an existing wire, so they have a stop on the one side for the end of the new wire. When doing this conversion, you will have two continuous wires extending thru both sides of the connector, so the stop will be in the way of the one wire.
10-30-2009, 12:16 AM | #8 |
Junior Member
Man, you got that right Captain, I spent a lot of extra time before I figured that part out!!
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! |
10-30-2009, 09:21 PM | #9 |
In lieu of "crimp-on" connectors, those have removable threaded caps. They are a little pricey, but they are heavy-duty, durable and make a lot tighter connection than the "crimp-on" style and the best part is, they can be removed and replaced, by unthreading the caps. I get them in the electrical section of O'Reilly Auto Parts. I forgot the technical/proper name for them or the manufacturer, but you should be able to get them in your area at most any FLAPS.
