Old 10-28-2009, 05:32 PM   #1
wrbenson
Lowering the front end
I didn't see this in the FAQ's so here goes:
If I get the 2.5" lowering spindles, is that all you have to do to get 2.5"? Or do I still need to cut a round out of the springs too? Thanks for any help on this subject.
wrbenson is offline   Reply With Quote
Old 10-28-2009, 05:55 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Lowering the front end
No, to accomodate the 2.5" drop up front, just throw on a set of 2.5" drop spindles and you will be set.
Unless... you are putting them on a 67-70. If so, you will have to update to disc brakes.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 10-28-2009, 06:29 PM   #3
sdime95
i would suggest new drop shocks as well
sdime95 is offline   Reply With Quote
Old 10-28-2009, 06:37 PM   #4
wrbenson
Thanks for the info guys. I have a 68, but it already has disc brakes. Who knows where from?
Old 10-28-2009, 07:37 PM   #5
SCOTI
SCOTI's Avatar
For spindle drops only, the shock requirements don't change (length of travel needed) so there's not much need for special 'drop' shocks. Off the shelf replacement p/n's would work too.
If shorter springs or bags are in the future plans & you're spending the coin for new shocks, drop shocks are the better investment.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-30-2009, 09:36 AM   #6
flamingbig10
6.0 powered square
flamingbig10's Avatar
if there 5x5 bolt pattern and they look unchanged in any way there from a 71-87 or they could be after market
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
