Old 10-28-2009, 08:35 PM   #1
chev-obsession
chev-obsession's Avatar
Question automatic trans conversion question
I have a 4 speed in my truck now and i want to put a turbo 350 in it. what would it take to do that? also would it make a difference if the tranny came out of a car or a truck?? would the tail shaft length matter any?
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 10-28-2009, 08:44 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: automatic trans conversion question
im interested also..
John
1999 Toyota Tacoma 4x4
Old 10-30-2009, 09:01 AM   #3
chev-obsession
i know someone on here has done this before.....
1965 c/10 swb
1969 c/10 lwb
Old 10-30-2009, 09:48 AM   #4
howard_m18
howard_m18's Avatar
Have done this 1 time a long time ago. Biggest concern is the length of the tail shaft length. Other than that, it ain't no challenge. I have a B&M pro shifter in mine. Howard
1967 C10 LWB, painted 2010 MUSTANG GRABBER BLUE & finally got it on the road after sitting in garage for 10+ yrs. Howard in MI.
howard_m18 is offline   Reply With Quote
Old 10-30-2009, 02:50 PM   #5
rwolf9653
more ideas than money
rwolf9653's Avatar
You will need:
radiator with trans cooler, or aftermarket trans cooler
trans lines
if column shift an auto column
if floor shift a floor shifter
the shift linkages (dont forget the throttle kick down on the carb)
automatic crossmember
change the flywheel/starter armiture
Also you might have to change the speedo gear or cable. I think just the gear though.
I'm not sure about tailshaft length differences, but you may need to lenghten or shorten the driveshaft accordingly.
Randy
1948 Chevy 3100 5 window
1966 Chevy C30 Dually
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1972 Chevy K5 Blazer
1987 Chevy V10
2003 Chevy Suburban
rwolf9653 is offline   Reply With Quote
Old 10-30-2009, 03:09 PM   #6
chev-obsession
do you know if you had a long or a short tail shaft?
1965 c/10 swb
1969 c/10 lwb
Old 10-30-2009, 04:19 PM   #7
cdowns
cdowns's Avatar
origanals came with the short 6"tailshaft//you also need to remove the crossmember that holds the manual tranny in place
Old 10-30-2009, 06:24 PM   #8
57larry
I'd like to have your clutch stuff, cause my turbo 350 is going out and I want to replace with with a muncie I have
57larry is offline   Reply With Quote
Old 10-31-2009, 07:55 AM   #9
RustyParts
RustyParts's Avatar
You'll have to remove the input shaft bushing from end of your crankshaft also.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 10-31-2009, 11:21 AM   #10
sweet70beast
sweet70beast's Avatar
Since your changing everything it doesn't mater if you use a long or short output because you'll have to shorten your drive shaft anyway. The 4spd trans is really short compared to the automatics.
By the way you will also need a yoke for the auto output because the 4spd yoke is bolted to its output.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 10-31-2009, 11:56 AM   #11
chev-obsession
we might be able to work something out.
So i need a short tail shaft turbo 350, the automatic crossmember, remove the input shaft, flywheel, starter, a shifter and linkages, tranny cooler and lines, a driveshaft, throttle kick down for the carb...... any thing else that i may of missed?
1965 c/10 swb
1969 c/10 lwb
