Old 10-28-2009, 08:42 PM   #1
koolky
67-72 Addicted
koolky's Avatar
Axle swap - will driveshaft work?
Im swapping out my Dana 60 rear for a 12bolt. will my origional driveshaft still work?
'72 K20
koolky is offline   Reply With Quote
Old 10-29-2009, 09:50 AM   #2
Burt4x4
Burt4x4's Avatar
Re: Axle swap - will driveshaft work?
Nope, yer u-Joint on the D60 is 1350 ~ can't remember the number on a 12b? But perrty sure it's smaller and your driveline may need to be shortend a bit..
This is all going of off 15yr memory so I could be loosing my mind...
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 10-29-2009, 10:07 AM   #3
chalet2506
12 bolts are 1310. Not sure about the length, but you a conversion joint will mate your shaft to the D60.
chalet2506 is offline   Reply With Quote
Old 10-29-2009, 07:41 PM   #4
koolky
67-72 Addicted
koolky's Avatar
Can I buy or build u-joints that are 1310 on the 12B side and 1350 on the driveshaft side? Or… can I get a 12B 1350 yoke? Are there any other differences between the 1/2 and 3/4 ton driveshafts?
'72 K20
Old 10-29-2009, 09:41 PM   #5
LkyDevilz72
LkyDevilz72's Avatar
Thumbs up Re: Axle swap - will driveshaft work?
Yes, they are called conversion u-joints. Just google it or call your local drive train repair place. It will have a 1350 on one end and 1310 on the opposite ends.
1972 Chevy C-10 Lowboy
1972 Chevy K5 Blazer Hi-boy
1948 Plymouth Club Coupe
LkyDevilz72 is offline   Reply With Quote
Old 10-29-2009, 10:07 PM   #6
70 beast
Certified Hobbiest
70 beast's Avatar
any reason for removing the d60???
my jimmy build
http://67-72chevytrucks.com/vboard/s...d.php?t=352536
70 beast is offline   Reply With Quote
Old 10-30-2009, 10:11 AM   #7
chalet2506
1310 to 1350 conversion joint part # (neapco) 3-3140 or (NAPA) NPJ P348.
Old 10-30-2009, 05:02 PM   #8
koolky
67-72 Addicted
koolky's Avatar
I bought a frame that came with a nice set of 1/2 ton axels with 3.07 gears. I’ll be running SM465 so I won’t have OD. My D60 has 4.10 gears in it. Plus brakes and stuff are a lot cheaper. I’ll probably use my D44/60 on a project one day.
'72 K20
