Old 10-29-2009, 07:33 AM   #1
bluex
bluex's Avatar
4x4 Axles.
I found someone local wanting a set of 4x4 axles with 3.08 or 3.42 gears.
I want to sell him the axles from my K5, according to the glove box they are 3.08's.
My question is, His truck is a 77, and the K5 is an 87. Both have 10 bolts, his truck has manual hubs.
What will be the differences between the two. I think his main concern is getting his manual hubs in my axles which have the auto hubs. Will anything concering the brakes (lines or anything) be different? I assume the track width and mounting points for the springs and steering components are the same?
bluex is offline   Reply With Quote
Old 10-29-2009, 11:13 AM   #2
Damien
Damien's Avatar
Re: 4x4 Axles.
The steering is different. He will need the '77 parts for the '87. I think everything else is ok, but maybe someone else can confirm. Might not hurt to move this to 4x4 section.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 10-29-2009, 11:00 PM   #3
ghettoluxury
ghettoluxury's Avatar
Re: 4x4 Axles.
It is a bolt in swap he just has to use his brakes. The lockouts in his current axle will swap into yours. The only differance is the gear ratio and calipers the 87's calipers had metric fittings.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 10-30-2009, 01:30 AM   #4
bluex
bluex's Avatar
Re: 4x4 Axles.
Thanks guys!
Well he will have all his parts and will hopefully be able to sell the 4.11 axles after the swap.
Damien - Do you know exactly what is different in the steering? I thought the difference in the brakes would be metric/standard threads.
I just want to make sure I know exactly everything he will need to change when I call him back.
Old 10-30-2009, 05:33 AM   #5
ghettoluxury
Re: 4x4 Axles.
The only difference in steering is the center link that runs between the two hubs if this is still attached on your axle than there is no need to change it. GM used 2 or 3 different style center bars from 73-87.
Old 10-30-2009, 07:16 AM   #6
bluex
bluex's Avatar
Re: 4x4 Axles.
Thanks,
I plan on unhooking the flex brake lines from the frame, pulling the pittman arm off the box and unbolting the axles from the leaf springs and giving it to him just like that. That way between the two, he should have everything he needs.
Old 10-30-2009, 09:36 AM   #7
LONGHAIR
Re: 4x4 Axles.
One thing to consider is that it will take a little more work than a simple hub swap. If you intend to keep the "automatic" hubs functional, you need to swap the locking ring from the spindle nut pack too. The automatic hubs need the four square tabs that stick out around the edges of that ring. It doesn't hurt a thing to leave them in there with the manual hubs, but you will need them if you want to re-use the autos.....not that I am recommending that LOL
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 10-30-2009, 12:24 PM   #8
Damien
Damien's Avatar
Re: 4x4 Axles.
The mount for the steering stabilizer is near the pumpkin for the '73-'76 trucks, for the '76-'80 and '81-'91 it near the ball joints. As long as you swap the steering with the axle you are fine.
