Old 10-29-2009, 10:25 AM   #1
96blazr
96blazr's Avatar
Muffler/Control Arm PICS NEEDED!!
Good day everyone. I'm in real need of Pics/Video of how you have run your Mufflers and Systems with our REAR control/Trailing arm suspensions.
I'm getting ready to install my AreoChambers and I really want to make sure I run my pipes right. I'm planning on going over the axle out the rear side, between the rear tire and the Bumper.
I need all the PICS of everyones systems that run Control arms, PLEASE!
Thanks to everyone.
1968 SWB.
GMPP 350/350 Turbo Trans, Edelbrock Performer & Carb. Hedman Hedders, Hooker Aerochambers Mufflers. Tuff Stuff Alternators.
Remember, no matter where you go,
There you are.
Gary
96blazr is offline   Reply With Quote
Old 10-29-2009, 12:03 PM   #2
mplex2000
mplex2000's Avatar
Re: Muffler/Control Arm PICS NEEDED!!
Why are you running exhaust under your front fenders? :p
mplex2000 is offline   Reply With Quote
Old 10-29-2009, 01:15 PM   #3
POPO1984
POPO1984's Avatar
I think he means trailing arms not control arms
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 10-29-2009, 01:24 PM   #4
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
He is correct, trailing arms are control arms. It is like the front upper and lower "A" arms are also front upper and lower control arms. "A" arms is slang as is trailing arms. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 10-29-2009, 03:48 PM   #5
96blazr
96blazr's Avatar
Okay, I edited it to be a little more clear. REAR Suspension, Trailing arms/Control Arms.
I don't want the mufflers under the cab and I'd like to get them as far back as possible before the Axle (that would the REAR axle ) and my main question is: can these be postioned in the area between the frame/Trailing arm and axle?
Plus, what about the routing of pipe to this point and the routing around/under the arm? ANY help will be greatly apperciated and ANY pics please.
1968 SWB.
There you are.
Gary
Old 10-29-2009, 04:37 PM   #6
mplex2000
mplex2000's Avatar
Just so you guys know, I know the front "a arms" are control arms, hence my joke
I've seen a lot of pics of guy's setups in the past...I'm a couple months out from running my exhaust. If you're still looking I'll post them when I do it!
Old 10-29-2009, 04:41 PM   #7
67chevemall
67chevemall's Avatar
I just cut mine off for the air bags. If ya close to Niagara you can have the tail pipes.
I have to dump before the axle now. Which I like better now anyways. More room for the fuel cell and getting at the bed bolts are easier now too.
Happy welding
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 10-30-2009, 09:17 AM   #8
96blazr
96blazr's Avatar
Thanks for everyones input. Now all I need are PICS!!!
1968 SWB.
There you are.
Gary
Old 10-30-2009, 10:25 AM   #9
BossHogg69
motor exploder
BossHogg69's Avatar
okay, this wasn't intended to be an exhaust pic, just ones I took when I got my truck to mark progress. Since my bed was so f'd up, you can see the exhaust! Mine was 2.5" pipe, routed under the cab, made a bend UNDER the front part of the control arm, then to the muffers. I had offest in/center out mufflers, with the mufflers mounted up & down ways instead of flat, with the offset pointing forward and closest to the ground, over the axle (center outlet) and straight out the back under the rear bumper. I have the old pipes cut out of the truck now, but I still have them and can take pics of them this weekend if you need them.
the red line is about where the trailing arm is, the yellow circle is the muffler. both sides where done the same, but you can only see the one. Hope this helps, I know the pic sucks!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 10-30-2009, 10:51 AM   #10
PR454SS
PR454SS's Avatar
here is a couple of mine a local shop installed. They dump right before the axle so can't help with tailpipe routing
PR Too many projects, not enough time!
72SWB 350/350TH, 3500stall,525 lift cam 3:73 posi. Sold!
69LWB Flatbed 350/Super T-10, ported/polished 481 heads, 480 lift cam.
78SWB 468/400TH, ported/polished Alum. heads, 3:42 posi, 3000 stall on 17x8 and 18x9.5's
77 Jeep CJ-5 304V8 fiberglass body on 36" Ground Hawgs
PR454SS is offline   Reply With Quote
Old 10-30-2009, 11:19 AM   #11
Hart_Rod
Hart_Rod's Avatar
I have several pictures of my exhaust in this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=369374
Hart_Rod is offline   Reply With Quote
Old 10-30-2009, 01:05 PM   #12
colinlx
colinlx's Avatar
Yep, mine is pretty well the same as the pics. I don't have any pictures of it, but the exhaust pipes run back and turn up just after that cross member that holds the center bearing for the drive shafts. My mufflers are next right in between the trailing arms before the rear axle, then the pipe goes over the axle and out the rear between the tire and bumper on each side. I'm not sure that there is any better way to do it if you want to dump the pipes between the back tire and bumper.
colinlx is offline   Reply With Quote
Old 10-30-2009, 01:13 PM   #13
96blazr
96blazr's Avatar
PERFECT!!! Those are FANTASTIC PICS Exactly what I needed. Thanks PR454SS!!
1968 SWB.
There you are.
Gary
