Old 10-29-2009, 01:54 PM   #1
ljackson
ljackson's Avatar
Alignment on '99 Yukon questions
Hi, I am usually on the 60 -66 forum. I recently bought a 2wd Yukon that is wearing tires on the outside. An alignment shop told me that they needed to remove the knockouts on the frame mounted bracket so they could get enough movement to adjust it. They want $150.00 to remove them. Are they telling me the truth? If they are, does the knockout side mirror the slot on the other side of the bracket? Can they actually be knocked out or do they have to be cut? If they have to be cut out, do you drill a hole at each end of the slot and join the holes with a die grinder?
Thanks for your help,
Jackson
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 10-29-2009, 03:33 PM   #2
clinebarger
Re: Alignment on '99 Yukon questions
Yes they have knock outs from the factory. Back when i was doing alignments i used a special tool to knock them out made by OTC. $150 is a smoking deal if it includes the alignment.
clinebarger is offline   Reply With Quote
Old 10-29-2009, 04:26 PM   #3
ljackson
ljackson's Avatar
The $150.00 is to remove the knockouts. $70.00 more to align. Thanks for the info
Old 10-29-2009, 04:42 PM   #4
clinebarger
Thats a little high. It whould take about 2 hours including the alignment.
get some quotes from other shops. And on another note if the camber and caster are within spec then toe in whould be the only thing that needs adjusting ( being toed in too far can cause outer tire wear) So if there trying to sell you this service without checking the alignment its just a up-sale you dont need. GM put those knock outs in there for a reason so the alignment will "hold" if they dont need to come out leave them alone
Old 11-03-2009, 07:25 PM   #5
truckdude239
truckdude239's Avatar
take it to another alignment shop and have them check it and not tell them about it and get there opinion
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 11-04-2009, 11:49 AM   #6
bwood
bwood's Avatar
You can have the alignment checked without removing the tabs/knockouts. I also believe you can adjust toe in/out also without removing the tabs/knockouts. If the camber is out, I would look at worn suspension components like, upper/lower ball joints and control arm bushings.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 11-18-2009, 10:28 AM   #7
ljackson
ljackson's Avatar
Thanks for the input. I took the knockouts out and took it to another shop. It is much better. I still have to steer it more than I think I should while driving on a straight highway. Any suggestions on this problem? I have not tried any steering box adjustments.
Old 11-18-2009, 05:47 PM   #8
truckdude239
they have the caster messed up sounds like to much negistve caster when would require alot of constant corrections on straight road
David fuller
2000 Tahoe 5.3l 378
Old 11-19-2009, 11:35 PM   #9
bwood
bwood's Avatar
Take it back and have them do it again. The father of one of my coworkers was alignment issues and had it lined up. He took it back and had them check it and they said it was in "spec". It continued, so he took it to the dealer and the alignment was ok, but he had a bunch of worn components that were letting it change while he was going down the road. I think he replaced all 4 ball joints, upper control arm bushings, and a tie rod end. Once it was all replaced, he took it back and had have it fine tuned, and the dealer said it ended up back almost in the factory locations.
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
Old 11-20-2009, 08:27 AM   #10
cparman
sharp as a marble
As you know now, you do have to remove the alignment knock outs. There are two for EACH control arm bushing mount. There are several companies that make caster/camber alignment CAMS to install in place of the original bolts. You need one of these kits to properly align the truck. These cams set caster and camber. If that truck has now worn parts, and is aligned properly it should drive perfect!
cparman is offline   Reply With Quote
Old 11-25-2009, 10:12 AM   #11
ljackson
ljackson's Avatar
cparman, my yukon has the eccentric washers for the bolts. Do I need something else or are we describing the same thing in different terms? By the way, I replaced all the worn parts. all ball joints, upper and lower control arm bushings, and a tie rod ends.
Old 12-13-2009, 04:28 PM   #12
cstm68
cstm68's Avatar
if you have the eccentric washers you should be good, (depending on how far out of spec it is) the plus side is you only remove the knock outs and install cam bolts once !
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 12-19-2009, 06:27 PM   #13
3r!c84
Badass
3r!c84's Avatar
hahaha i do it myself for FREE at my high school
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
