Old 10-29-2009, 02:10 PM   #1
78-5.3
78-5.3's Avatar
choping springs
ok i know its taboo to cut coil springs but i just ordered 3" spindles and i wanna see what 2" off the coil will look like on my truck or if i go 3" so if anyone knows how much to cut off that would be great im not gonna cut the coil with a gas axe im cutting with a angle grinder to help keep heat down!!!!
78-5.3 is offline   Reply With Quote
Old 10-29-2009, 02:17 PM   #2
MotorHead Lon
MotorHead Lon's Avatar
Re: choping springs
Cutting one coil gives about 2". Most of my trucks have cut stock springs and lowered spindles. Just dont cut more than one coil.
88 Chevy C1500, step side, LS swap.
98 Crew Cab Dually, tow rig.
03 Dodge Neon. ECTA Ohio Mile record holder.
MotorHead Lon is offline   Reply With Quote
Old 10-29-2009, 02:35 PM   #3
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: choping springs
Noth ing "wrong" with cutting coils. Some people may advise against it, but I have had many a truck with cut coils with no issues with ride or anything else. Just keep the head down and just cut one coil.
--Josh
Old 10-29-2009, 02:42 PM   #4
Keith Seymore
Keith Seymore's Avatar
Re: choping springs
Yep - we did 7 or 8 trucks like that back in the day with no issues.
My current driver has 23 years and 180,000 miles of "durability testing" with no problems.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-29-2009, 03:08 PM   #5
78-5.3
78-5.3's Avatar
Re: choping springs
thx for the speedy replys so i should cut 1 1/4 coil LOL
OK Another question _ top or bottom
i forgot to add my truck was a fatcory diesl if that matters
Old 10-29-2009, 03:32 PM   #6
STOCKISH
STOCKISH's Avatar
Re: choping springs
only cut the Bottom of the coil.
--Josh
Old 10-29-2009, 04:01 PM   #7
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: choping springs
K
No problems with my 83 and 2 cut coils and 207K miles
Malo83 is offline   Reply With Quote
Old 10-29-2009, 04:19 PM   #8
ironroad9c1
Master Hater
Re: choping springs
yea , nothing wrong with cutting em, (The right way) and that is to set em in a 5 gallon bucket of water with the coil you want to cut just above the water,cut with a portaband , or a angle grinder, something that cuts quick and doesn't put much heat in the springs.. Heating up springs to drop something is what is taboo.
ironroad9c1 is offline   Reply With Quote
Old 10-29-2009, 05:34 PM   #9
78-5.3
78-5.3's Avatar
Re: choping springs
good idea!!!
Old 10-29-2009, 05:36 PM   #10
78-5.3
78-5.3's Avatar
Re: choping springs
while we are on this subject i also ordered the flip kit for the rear i measured the tube 3" and the leafs (8) another 3" for the flip is 6" right i know i can count LOL but that how you work out the flip????
Old 10-29-2009, 06:11 PM   #11
3r!c84
Badass
3r!c84's Avatar
Re: choping springs
a flip is 5ins but i can be more like 6
did you see my truck on finally low. that was a 3in dropspindle and a flip,and i still neeed more drop upfront
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 10-29-2009, 06:29 PM   #12
78-5.3
78-5.3's Avatar
Re: choping springs
mine has the 8 leafs and when i measured the leafs it was 3 " and the tube 3" so mine will be 6" hopefully !!!
Old 10-29-2009, 06:36 PM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: choping springs
yea , nothing wrong with cutting em....... Heating up springs to drop something is what is taboo....
There ya go. Cutting is cool, heating not so much.
I know it's extra work, but I suggest you cut one coil and put it back together. You can always cut more off if it's not low enough, but it don't work so well trying to glue it back on.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-29-2009, 06:39 PM   #14
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: choping springs
Depending on the age of the spring, I generally cut a 1/2 a coil and put it back in and drive it. (remove it by taking the rear lower control arm mounts off) and if that is not enough drop another 1/2 and put it back in and drive it. after a full coil I generally cut around 1/8th off at a time to find tune it. IF you find one side is higher than the other, flip them around.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 10-29-2009, 08:09 PM   #15
78-5.3
78-5.3's Avatar
Re: choping springs
another thing i was wondering is pinion angle ! and drive shaft length are these altered when you lower a truck 5/7
Old 10-29-2009, 08:12 PM   #16
3r!c84
Badass
3r!c84's Avatar
Re: choping springs
what kit did you order for the flip
-00 Saturn 5spd
1/4:13:90
Old 11-07-2009, 12:14 PM   #17
78-5.3
78-5.3's Avatar
Re: choping springs
there a guy out of MA on ebay like 50 bucks delivered then i ordered new u bolts from LMC trucks another 65 bucks delivered
Old 11-07-2009, 12:40 PM   #18
3r!c84
Badass
3r!c84's Avatar
Re: choping springs
oh what did it come with?
-00 Saturn 5spd
1/4:13:90
Old 11-07-2009, 06:18 PM   #19
78-5.3
78-5.3's Avatar
Re: choping springs
the flip bracket for the rear end
Old 11-07-2009, 06:20 PM   #20
3r!c84
Badass
3r!c84's Avatar
Re: choping springs
no bumpstops ?
on the bracket is the hole off centered ?
-00 Saturn 5spd
1/4:13:90
Old 11-07-2009, 06:27 PM   #21
78-5.3
78-5.3's Avatar
Re: choping springs
ok i cut my coils today !!! i measured from the ground to the fender lip before i took it apart and it was 33" after i cut 1 1/4 coils off it lowered the truck to 31" my tires are around 29 inch tall that leave 5" from the top of the tire to the innner fender now im waiting for my drop spindles they are DJM 3'' drop with my 29'' tire this only leaves 2 inch also im sure the fender lip will be around 28" does any one have an problems with the tires hitting the inner fender my rims and tires are stock !!!!
Old 11-07-2009, 08:36 PM   #22
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: choping springs
The springs will probably settle a little. Your going to need a shorter tire once you put the spindles on.
Articles-
"Refining Sierra"
Old 11-07-2009, 09:03 PM   #23
78-5.3
78-5.3's Avatar
Re: choping springs
no bumpstops ?
no bumps the holes are off center worked great! nice thick construction!
Old 11-07-2009, 09:05 PM   #24
78-5.3
78-5.3's Avatar
Re: choping springs
i like that hi profile look hoping to keep a tall tire but if not then i will go shorteR!!
Old 11-07-2009, 09:47 PM   #25
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: choping springs
i have 215/70s about 27" tall on my truck and can barely get my hand to fit in between the inner fender and top of the tire and from the wheel well lip to ground is 24 3/4 for me
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
