Old 10-29-2009, 07:53 PM   #1
Wildstreak
"something witty here"
Wildstreak's Avatar
lift kit questions???
Ive been saving money for a blazer or starting a project I already have(Im the kinda person that changes their mind every five seconds lol). The question is if I buy a lift kit say for my swb 4x4 will it work with a blazer I get down the road? Or will I have to get a different lift?
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 10-29-2009, 09:44 PM   #2
LkyDevilz72
LkyDevilz72's Avatar
Re: lift kit questions???
I think so? Just measure the length of the rear springs. Its something like 52 inches and i think they are all the same so it should work.
1972 Chevy C-10 Lowboy
1972 Chevy K5 Blazer Hi-boy
1948 Plymouth Club Coupe
LkyDevilz72 is offline   Reply With Quote
Old 10-29-2009, 10:09 PM   #3
70 beast
Certified Hobbiest
70 beast's Avatar
i put a lift kit off a gmc k25 on my 71 jimmy, and it sits a bit low in the back. i believe its a common problem with doing this kind of swap. kits that are specifically for blazers/jimmys use a larger lift in the rear to compensate for the saggy a$$ syndrome.
my jimmy build
http://67-72chevytrucks.com/vboard/s...d.php?t=352536
70 beast is offline   Reply With Quote
Old 10-29-2009, 10:10 PM   #4
2tons of fun
depends on the extent of the kit.
99% will swap but like ld said, if you get rear springs they may not match up, all chevys could have had 52 or 56" springs.
the fronts, steering, ubolts and blocks will all swap, with respect to bodystyles. ie a 60-72 front spring will not work with 73-91.
2tons of fun is offline   Reply With Quote
Old 10-29-2009, 10:39 PM   #5
Wildstreak
Wildstreak's Avatar
chances are the lift will stay in the shortbox, but if I get a blazer in spring and dont have much extra cash I would like that to be an option. Thanks for the info guys
57 chevy 4x4
68 burb 2wd:
Old 10-30-2009, 05:07 AM   #6
409sbc pwr
409sbc pwr's Avatar
i know if u get a superlift it will work for the swap just fine im sure its the same with many other brands
84 3/4ton swap 4x4, 409sbc 37x13.50 toyos 8 inch superlift
2007 2500 HD, 10-12 cognito lift, 38x13.50 toyos soon to be boosted via rearmount system
409sbc pwr is offline   Reply With Quote
