Old 10-29-2009, 08:22 PM   #1
tferbend
1966 Rear End Swap
Can someone tell me what year truck (car?) rear ends will fit my 1966 chevy pickup? (preferrably posi/5 or 6 lug)
I tried looking in the 1960-66 forum first, but no luck. i guess i'm too computer illiterate.
Thanks,
Tom
Houston, TX
tferbend is offline   Reply With Quote
Old 10-29-2009, 08:42 PM   #2
Oklahoma
Re: 1966 Rear End Swap
You could put any rearend in it that you want, all you have to do is change the axle perches.
Oklahoma is offline   Reply With Quote
Old 10-29-2009, 09:05 PM   #3
47guy
there are kits out there like this one
http://www.classicperform.com/Store/...ck/6072RCK.htm
looks like it would make it pretty simple and the price isnt bad
47guy is offline   Reply With Quote
Old 10-29-2009, 09:13 PM   #4
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Tom 63-69 is the same size from drum to drum. 63-64 are a 14 spline axle. 65 and up went to 30. 70-87 is a little bit wider then ours. You can still use this axle you will just have to get the correct back spacing wheels. Also 71 they changed to 5 lug. 63-70 is 6 lug. I hope this helps some.
check out this website. www.car-parts.com just look for axles in texas and you'll find a bunch.
what are your plans with the one you have now and what gears in it?
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 10-30-2009, 09:00 AM   #5
tferbend
about my old rear end?
i dont know, i havent given it much thought.
it has 3.73 gears (confirmed by counting ring and pinion teeth and dividing the # of ring teeth by the # of pinion teeth)--but i dont think it's posi.
I read on the Internet (yeah, i know...), that limited-slip gears ARE posi-trac gears.
i thought limited-slip only transferred torque/power to one rear wheel. whereas posi-trac transferred torque/power to both rear wheels.
now, i'm totally confused. =(
how do i go about confirming if a rear end is posi or not?
Old 10-30-2009, 09:34 AM   #6
tferbend
another thought...
if i found 2 rear ends--a 63 (14 spline) and a 66 (30 spline), the 30 spline is stronger... correct?
i seem to remember reading that it is.
with my mods (350V8/700R4), i'm guessing i should find a 65-66 rear end.
Old 10-30-2009, 09:37 AM   #7
tferbend
also, are the 65-66 chevy truck rear-ends posi?
Old 10-31-2009, 12:13 AM   #8
shaunj
I got my local diff specialist to weld in a 9 inch Ford head so I have full choice of ratio,s and its still in my 8 lug full floater No cables to change and all stays the same...
shaunj is offline   Reply With Quote
Old 11-01-2009, 01:36 PM   #9
777ralph
If by "fit in my truck" you mean "bolt in", then newest is 1972. I think 68-72 are 5 lug. The 30 spline would be a stronger rear than 14 spline, but if you're not beating on it you may never need that extra strength. Are you building a street truck or a drag racer? Gear ratio availability is more relevant I think, but a 3.73 with a 700r4 Sould work nice with a 28 to 30 inch tire height. If you're doing a 5 lug axle swap, just be careful with wheel backspacing. According to Lolife99 in the "track width" thread I started, http://67-72chevytrucks.com/vboard/s...83#post3595683 ,the 73-87 axles are 3/4 of an inch wider.
Ralph
777ralph is offline   Reply With Quote
Old 11-01-2009, 10:29 PM   #10
ruffrida2005
65-69 are the same 30 spline axle, Some are posi and some are open spider gears. 70-87 are wider, but you can bolt them in with the correct backspacing rims. 71-87 are 5 lug rims. 65-70 are 6 lug. Your best bet is to find a axle from 65-69 with a posi or just buy a posi with the correct gears you wanna run.
Paul
Old 11-02-2009, 01:19 AM   #11
Captainfab
60-66 Nut
The '71-'87 C10 differentials are 1.5" wider than the '63-'69 C10 differentials. I understand that there is some question on the width of the '70 C10differentials.
Old 11-02-2009, 08:06 PM   #12
ruffrida2005
thanks for the input on the 70 captain I didn't know that!
Paul
