Old 10-29-2009, 08:44 PM   #1
47guy
3/4 and 1 ton front ends
does anyone know what the difference is in the front ends of the the dually trucks and the single wheel trucks? i have a dana 60 rear end and was thinking about using it on my 65 i can get the front end for free but its from a dually and i wasnt sure if it would work i figured this was the best place to ask thanks for the help.
47guy is offline   Reply With Quote
Old 10-29-2009, 10:50 PM   #2
ghettoluxury
ghettoluxury's Avatar
Re: 3/4 and 1 ton front ends
You have to change out the hubs to single wheel hubs
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 10-30-2009, 12:24 AM   #3
pig rig
pig rig's Avatar
the dual rear wheel front rotors have the hub casted in to them all you need to do is change the rotors from the drw to the srw rotor the spindel and caliper are the same
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 10-30-2009, 02:03 AM   #4
2tons of fun
no they dont, but drw rotors are different than srw rotors.
d60 front drw hubs can have the outer lip machined off and be turned into srw setup. the drw rotors have a slightly smaller hole and are BOLTED to the hub.
srw rotors are pinched to the hub with the wheel stud, like a d44/10b. you can drill the holes out if need be.
drw rotors are also thicker, but they will still use the same caliper and pads.
keep the drw and use h1 wheels.
2tons of fun is offline   Reply With Quote
Old 10-30-2009, 12:55 PM   #5
pig rig
pig rig's Avatar
it looks like casted as one to me. the one's that i just took off look the same along with the new ones I put back on
this is srw
Old 10-30-2009, 06:30 PM   #6
47guy
thanks for the help the pics really made it clear as to what is needed to run this thanks again
Old 10-30-2009, 07:56 PM   #7
manimal
manimal's Avatar
so thats it,just change out the rotor from dually to single..?????The spindles are the same?!?!?!...........AWESOME
I have a set of drop spindles for a 1ton and I guess the 3/4t is the same thing!
Sorry to HIJACK
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 10-30-2009, 09:48 PM   #8
pig rig
pig rig's Avatar
the caliper is differant between the 1T and the 3/4 and I dont know if theirs a differents between the thickness of the rotors on the 3/4T and the 1T's
Old 10-30-2009, 10:15 PM   #9
2tons of fun
this is srw
you are right, once again i repeatedly read the first post wrong, i thought he was putting a d60 FRONT 4wd in.
sorry.
