Old 10-30-2009, 03:27 PM   #1
Wildstreak
"something witty here"
Wildstreak's Avatar
700r4 question???
I just found a 700r4 and transfer case in great condition and want to use it on my swb 4x4, I noticed that the steering columns have more than just P_R_N_D_2_1, the question is will I have to replace my steering column or just get a new gear indicator for the column?
Thanks for the help as always
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 10-30-2009, 03:38 PM   #2
smoky02
Location: Sunny, Florida, some might call it South Alabama
Re: 700r4 question???
You will just need to order a new gear indicator.
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 10-30-2009, 03:41 PM   #3
Wildstreak
Wildstreak's Avatar
thanks smoky02
any ideas where to find a good one?
57 chevy 4x4
68 burb 2wd:
Old 10-30-2009, 04:20 PM   #4
Wildstreak
Wildstreak's Avatar
will I need to get a torque converter lockout kit as well? What exactly do i need to make the 700r4 feel at home lol
57 chevy 4x4
68 burb 2wd:
Old 10-30-2009, 06:08 PM   #5
Wildstreak
Wildstreak's Avatar
ttt
57 chevy 4x4
68 burb 2wd:
Old 10-30-2009, 06:30 PM   #6
cparman
sharp as a marble
do a search in the FAQ section. I have a 700 in my Blazer. I wired it to be able to manually lock up the converter with a toggle switch, but also unlock it thru the stop light switch. This way if you are putt putting around town you can leave the converter unlocked. but if you are cruising 50 + you can lock up the converter.
cparman is offline   Reply With Quote
Old 10-30-2009, 07:19 PM   #7
Wildstreak
Wildstreak's Avatar
do you need to run a lock up torque converter?
I tried the search but it never seems to get every post titled for some reason....
57 chevy 4x4
68 burb 2wd:
Old 10-30-2009, 08:59 PM   #8
cparman
sharp as a marble
Just got home from dinner. A 30 mile ride in my Blazer with my wife. I will send you a pm tomorrow with detailed info on why and how to wire the lock up converter you need. If this old fat man spaces, remind me on Sunday that I dropped the ball. It is beer thirty!
Old 10-30-2009, 09:25 PM   #9
Wildstreak
Wildstreak's Avatar
Thanks cparman
I actually remembered by just goin to the faq and looking that I find stuff easier, Idk why they dont tun up on searches. I found out all the info I need now I just have to figure what company to get the lock up kit from. Ive found a few but am completely clueless as to whats the best product. Any suggestions?
57 chevy 4x4
68 burb 2wd:
Old 10-30-2009, 09:48 PM   #10
cparman
sharp as a marble
I would think that you would want lock up in 4th gear only. Find a local trans shop and ask them to wire the trans this way. the electrical connector for the trans is available from your local ACDELCO SUPPLIER. the purple wire in the connector is what you want to be 12v hot.
12v+ key on thru a 4 terminal brake lite switch, thru a toggle switch to the trans 'A' terminal at the connector.
Mine is that way, and works perfect
Old 10-30-2009, 10:00 PM   #11
Wildstreak
Wildstreak's Avatar
from what Ive read a few people are using thishttp://www.summitracing.com/parts/TC...0/?image=large it looks to be what I need....
57 chevy 4x4
68 burb 2wd:
Old 10-31-2009, 06:12 PM   #12
Indyuke
In the later (88 and later, i think) 700 transmissions, you don't absolutely need to have the converter lockup, though it helps with fuel economy. The early '80s will overheat too easily without the lockup.
Indyuke is offline   Reply With Quote
Old 11-01-2009, 12:08 PM   #13
Jurassic-1
Jurassic-1's Avatar
I have a 700r4 in my 72 cst Blazer. I put the lockup on a seperate dimmer switch and an indicator light under the dash. It works well. I found that you must use a adjustable throttle bracket to insure a fully open valve inside the trans. I purchased one from Bowtie transmissions. These guys seem to know all about 700r4 installs. They sell veverything you need. I see them in the Pamona CA. swap meet and the have always been helpful to me.
Jurassic-1 is offline   Reply With Quote
Old 11-01-2009, 07:34 PM   #14
Wildstreak
Wildstreak's Avatar
another question.....what should i use for the tranny transfer case crossmember? From the truck I pulled the tranny from or???
57 chevy 4x4
68 burb 2wd:
Old 11-02-2009, 10:52 PM   #15
Wildstreak
Wildstreak's Avatar
another question lol, the engine its going with is a 454 and I need a flexplate anyways so what would be the best one to get?
57 chevy 4x4
68 burb 2wd:
