10-30-2009, 05:02 PM | #1 |
steering column
i have a 1978 chevy k20 frame with a 1985 body. i changed the column from a 1986 chevy and everything was good and now when i put the key in and turn it to accessories the gear shifter goes down and i have to pull it up and turn the key to start it and same to take the key out. anybody have any ideas
10-30-2009, 07:15 PM | #2 |
Robert Olson Transport
Re: steering column
that doesnt make sense if the linkage is hooked up.. that would hold it in place
10-31-2009, 08:44 AM | #3 |
Re: steering column
I believe your shift rod needs adjustment. Pinch bolt needs to be loosened (while in park) and moved a little bit. Once loosened it will want to move in the direction it needs to go. If it's not rusted it may self-adjust while loose. Shouldn't move very much. Be sure to torque nut before checking.
11-01-2009, 11:18 PM | #4 |
Re: steering column
Thanks for the info will try that
