Front end gear ratio? 4x4
I am trying to figure out the ratio on on the front axle of my 4x4 with out pull ing the cover. It is an 8 lug dana 44, open disk.
When I jack up one wheel and lock both hubs the driveshaft will turn just over two revolutions per wheel revolution. I assume that this would be 4:10 (1/2). I have only done this with rear ends before. Am I supposed to do two wheel revolutions?
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job" |
Re: Front end gear ratio? 4x4
look for a tag on the rear axle its gonna be the exact same ratio or very very close to the front ratio.
yes, 2 revs makes it a little easier it id.
Yes, 2 turns of the wheel. 4.10 should be correct. What ratio is your rear axle?
Tim |
Your Dana44 front axle should be 4.09:1.
So I could pair this up with a 14 bolt 4:10 or 4:11? Currently this frame has a dana 60 that is wider, halfway mounted in to it. The perches would have to be moved. I would rather move and make a 14 bolt work.
#7 | |
Yup, the factory did it all the time.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
