Old 10-30-2009, 10:54 PM   #1
bw4sale
bw4sale's Avatar
Notch is off.
I'm converting a '68 leaf truck that was already notched with a flip kit to a bagged trailing arm set up. In the mock up I'm noticing that the axle needs to move back about an inch or a little more to really sit in the notch. Why would this be. The leaf axle sat right in the notch. I'm going to stick the bed on tomorrow and see what it looks like. I may have to add a spacer between the trailing arm brackets and the crossmember.
BRENT
-'68 Stepside Project
-'98 Z71 Daily Driver
-Enough extra parts to build another truck and a half
bw4sale is offline   Reply With Quote
Old 10-31-2009, 12:08 PM   #2
bw4sale
bw4sale's Avatar
Re: Notch is off.
Pics. Any suggestions????
Leaf -
Trailing arms w/bags
BRENT
Old 10-31-2009, 01:25 PM   #3
bw4sale
bw4sale's Avatar
Re: Notch is off.
Got the bed on. I was hoping the wheel would be about an inch or two off so I would know what to do, but it's not. Looks pretty centered to me. Now I don't know what to do. I'm so frustrated.
BRENT
Old 10-31-2009, 01:29 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Notch is off.
Do you have your trailing arm crossmember "located" correctly?
Your wheels base should be 115 inch.
Edit: (I'm a slow typer)
Looks centered in the rear fender to me.
I would still check the wheelbase length.
Keith
Convert to disc brakes.
Old 10-31-2009, 01:32 PM   #5
lolife99
lolife99's Avatar
Re: Notch is off.
I would cut out the "weld in" c-notch and purchase a bolt in c-notch. The frame hole will be slightly bigger,... but the extra metal from the bolt in notch will help support it. You could even add some welds to the bolt in notch if you are worried about it.
Keith
Old 10-31-2009, 01:46 PM   #6
bw4sale
bw4sale's Avatar
Re: Notch is off.
I did measure where the middle crossmember was and compare it to the one on my coil frame. It measured out right. I just drilled out the rivets on the trailing arm brackets and bolted them to the crossmember on the leaf frame.
BRENT
Old 10-31-2009, 02:52 PM   #7
kev2809
low n' slo
kev2809's Avatar
Re: Notch is off.
that is odd,. guess that means you need a step notch!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 10-31-2009, 03:03 PM   #8
bw4sale
bw4sale's Avatar
Re: Notch is off.
Very tempting.
BRENT
Old 10-31-2009, 03:43 PM   #9
Slow Build
Slow Build's Avatar
Re: Notch is off.
Did you check this yet?
That's where I would start.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 10-31-2009, 04:01 PM   #10
bw4sale
bw4sale's Avatar
Re: Notch is off.
Well, the front end is off of it right now. It's down to the bare frame in front. Is there a way to check it without the front crossmember?
BRENT
Old 10-31-2009, 04:03 PM   #11
71swb4x4
71swb4x4's Avatar
Re: Notch is off.
If that picture of the wheel in the fender is a straight on shot, then the wheel is back a good inch or two too far.
Follow the fender curve around and note where the tire finally cuts in and out of it. It cuts in way earlier in the back than the front. The wheel is definitely too far back in that picture.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 10-31-2009, 04:30 PM   #12
bw4sale
bw4sale's Avatar
Re: Notch is off.
There's not really anything I can do about that short of moving the crossmember. If I moved the axle back to fit the notch, then it would really be too far back.
BRENT
Old 10-31-2009, 04:36 PM   #13
Slow Build
Slow Build's Avatar
Re: Notch is off.
But the pictures show the axle is forward of the notch, like the wheelbase would be shorter not longer. It's a head scratcher.
Past GM Trucks:
