10-30-2009, 11:00 PM | #1 |
Triple convoluted aribags
Is anyone using them? Im thinking about getting a set for my body-dropped project, What I know is that they provide more "lift" but what about cons? If there are any. Heres how they look like..
10-31-2009, 11:44 AM | #2 |
Re: Triple convoluted aribags
Ttt
11-01-2009, 01:49 AM | #3 |
I guess nobody has them on their rides yet huh? Thats kool, I will buy them and try them out for the rear of my 68 cst project, will let ya all know how they work out
Puropedo's 68 CST project : http://67-72chevytrucks.com/vboard/s...d.php?t=362405 |
11-01-2009, 12:07 PM | #4 |
Happy to be here
You might send a PM to 87 dually burb He has them on the back of his 90 Burb.LINK The biggest problem I see is the fully collapsed height will not allow you to go as low as a double convoluted.
11-01-2009, 07:38 PM | #5 |
3DrDwn--the 'burb not the band
one of the other drawbacks is they consume a larger volume of air so tanks are depleted faster. With the larger volume also comes a softer spring rate for a given pressure. I was talked into using the taper sleeve for my burb in the rear and will probably use that style although something more HD than the F9000 in my dually. The sleeves use even less air than a double convolute and have a very linear spring rate throughout the travel. I have nothing against double or triple bellows just liking the sleeves a touch better.
Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 4x4 crew DD duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
11-03-2009, 10:53 PM | #6 |
I've used these(http://cgi.ebay.com/ebaymotors/Unive...Q5fAccessories) bags on my RCSB for about 4 years with no issues. Not to sure on what you are looking for, but I use them over axle and get about 12.5" of lift. They compress to just over 3".
Dale |
11-03-2009, 11:38 PM | #7 |
my short bus
funny I just found this
I have them in a axle over set up let me know if you have ?'s about them
**90 burb**bagged,shaved**(about done)********* **91 burb**stock worker for now**************** *********only squares for me****************** |
11-04-2009, 07:49 AM | #8 |
low n' slo
I always thought about triple bags too but never got them because I would need flat out more than lift. looks like ur gonna lose some drop with those compared to double bags..I would just toy around with bag placement with double or sleeve bags to get the most lift...jmo let us how know it goes
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
11-13-2009, 10:42 PM | #9 | |||
Thanks 87 dually,I was a little skeptical about them, now I have them and will be using them on my project, I will hit you up if I have any question. |
