Old 10-31-2009, 01:14 AM   #1
jess66chevy
jess66chevy's Avatar
Who has a REAR Sway Bar?
Are you guys running a rear sway bar in the rear? My truck is so LOW that it would that installing a rear sway bar would sit even lower. Do you have any pics of a rear sway bar installed? What are the benifits of a sway bar in the rear?
jess66chevy is offline   Reply With Quote
Old 10-31-2009, 05:23 AM   #2
Joemomma1
Joemomma1's Avatar
Re: Who has a REAR Sway Bar?
I have one off an 89 Trans Am. Its hard to find them for a rear coil set up. This thing runs above the axle tubes and over the pumpkin. Its 2" wider than it needs to be, so 1" wider on each side. I welded up a 1" deep 4" tall and 2" wide piece of satinless to the frame and bolted it up to that w/ grade 8 harware. I will take som pics of it and post it up
Joemomma1 is offline   Reply With Quote
Old 10-31-2009, 10:35 AM   #3
TheDark1
Intentionally Left Blank
TheDark1's Avatar
I have one from Early Classic. It hangs below the differential, but I haven't had it high center on anything yet. The truck is fairly low also. I put a picture with a tape measure for reference. The only thing I did different was in the instructions, it came with some wimpy little clamps. I tossed those and bolted the bushing straight to the trailing arm.
Name:  65 Chevy Truck 001.jpg
Name:  65 Chevy Truck 007.jpg
Name:  65 Chevy Truck 009.jpg
1965 C-10 Short Fleet 468/TKO 5-Speed
2004 2500HD Crew 496/Ally Blacked Out (SOLD!!)
1997 Formula WS6
2004 Jeep Wrangler (Sold)
2013 Jeep Wrangler (Sold)
2017 Jeep Wrangler (Blacked Out on 35's)
2011 GMC D-Max Dually Denali 3500HD (Sold)
2015 GMC D-Max Dually Denali 3500HD (Sold)
2018 GMC D-Max Dually Denali 3500HD (Sold)
2020 D-Max Dually Denali on 33x12.50's
1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles
TheDark1 is offline   Reply With Quote
Old 10-31-2009, 02:22 PM   #4
Slow Build
Slow Build's Avatar
For some reason that just looks wrong to me. Maybe it's because it is the complete opposite of the way a front sway bar is attached.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 10-31-2009, 04:27 PM   #5
jess66chevy
How much did you guys buy it for? A place is selling one here in AZ for $50. Im considering it!
Old 10-31-2009, 04:35 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
[QUOTE=TheDark1;3595624]I have one from Early Classic. It hangs below the differential, but I haven't had it high center on anything yet. The truck is fairly low also. I put a picture with a tape measure for reference. The only thing I did different was in the instructions, it came with some wimpy little clamps. I tossed those and bolted the bushing straight to the trailing arm.
How about the handling. Did it make a big difference?
Old 10-31-2009, 05:59 PM   #7
TheDark1
TheDark1's Avatar
Yeah it helped. It's pretty stiff with the lowered springs. I was thinking about softing up the spring rate a bit, but after driving my 2500HD and putting some more miles on the '65, it doesn't feel too bad. It gets a little upset on the really fast bumps, but on a smooth road, it stays very flat. I just checked my receipts, and I actually got it from Summit Racing. It's a Hellwig brand. The Summit # is HEL-7401. In the year 2000 it was $129.69 now it's $253.69. I guess they think it's twice as good now. 50 bucks is a steal.
1997 Formula WS6
Old 11-04-2009, 09:03 PM   #8
vin63
It's Better With Nitro
vin63's Avatar
...since I was out of room with my truck being so low, I did a torsion bar through the frame for the rear end. I needed to install a cross member behind the rear end housing anyway, so I used some leftover tubing and went with a splined sprint car-type torsion bar and arms.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 11-08-2009, 09:45 PM   #9
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
Jess, check this out (I'm thinking of doing it this way)(this may be what Joemomma has):
http://www.low69cst.freeservers.com/CamaroBar.htm
Larry
fleetsidelarry is offline   Reply With Quote
Old 11-30-2009, 07:36 PM   #10
Joemomma1
Joemomma1's Avatar
A year later.....
All that dirt and it hasnt been driven once. I suppose you can use whatever you want as far as the spacer. I had the stainless piece on hand so I went with it. Your going to need 2.75" muffler clamps instead of the u bolts that come from the camaro/trans am and will also need to make the holes on the bushing hold down a little bigger.
Old 11-30-2009, 11:28 PM   #11
62gmc910
62gmc910's Avatar
I used a late 70S 4x4 front sway bar mounted above and behind the the diff,
but you could mount it in front for fuel tank clearance I don't have pics because I took it off, it made the truck oversteer (loose)
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 11-30-2009, 11:43 PM   #12
jess66chevy
Joemomma,
Thats a pretty trick set up!
Old 12-01-2009, 02:32 AM   #13
Joemomma1
Joemomma1's Avatar
Joemomma,
Thanks. I like it alot, looks to me like it belongs. It also sits above the rear end so it should'nt matter how low your truck is. I got the idea from jess69cst I think. You dont have to weld the spacer on but I wanted to make sure the mounting point was solid. About 12 for the bar and mounts and 3 for the muffler clamps. I have'nt driven it yet so I cant tell you how well it works.
Old 12-01-2009, 10:03 AM   #14
fleetsidelarry
Senior Car Nut
Joemomma, great pictures! neat idea with the muffler clamps (did you mean to say 3" clamps?) $12 for the sway bar? now that's a deal
Larry
Old 12-01-2009, 05:47 PM   #15
Joemomma1
Joemomma1's Avatar
No, its was 2.75". Thats a 8.8" not a 12 bolt. I think the diameter of the tubes are the same between the two. The saddles are for a 12 bolt.
