Old 10-31-2009, 06:19 AM   #1
navysnipe
navysnipe's Avatar
Leaf springs
I am slowly getting my 70 C20 and 72 K2500 tore down to a point that I can make one good truck. My Dads 70 C20 body is going on my Uncle's 72 K2500 frame and running gear. I am to the point were the frame is almost bare and I just cut the rear leaf springs out and am replacing the spring eye and shackle bushings. That job is a B@&CH, those bushings just laughed at my 12 ton hydraulic press. I finally had to press the centers out and take a sawzall to the outer shell.
The question is when I go to reassemble the rear and the front for that matter do I tighten the bushing bolts while the springs are dangling or do I put weight on them then tighten them. I would imagine that tightening them while they are in the air will sort of preload the rubber and put a twist in them and that doesn't sound right. Also I plan on using POR-15 on the springs anyone have any problems with cracking of the paint after?
Navysnipe
navysnipe is offline   Reply With Quote
Old 10-31-2009, 08:50 AM   #2
JimKshortstep4x4
Re: Leaf springs
You will want the weight of the truck on the springs before tightening the bolts. You are right about the preload.
I usually burn the rubber out and then cut the shell with an air tool.
I have used POR on springs and so far so good.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 10-31-2009, 04:26 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Leaf springs
you want the weight on the suspention before tightening anything down. Complete vehicle weight too, not just frame and cab.
Old 10-31-2009, 06:49 PM   #4
navysnipe
navysnipe's Avatar
Re: Leaf springs
Thanks,
I will put everything together and wait to get everything on it then torque the bolts as one of the last things
Navysnipe
Old 10-31-2009, 07:37 PM   #5
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
Re: Leaf springs
I use to be a snipe. Well sort of EM, I think it still counts.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 11-01-2009, 07:19 AM   #6
navysnipe
navysnipe's Avatar
Re: Leaf springs
EM's are still snipes, they get dirty and nasty with the rest of us. I was an MM for 10 years and then a GS for 10 more years.....now I raise chickens. Much cleaner job
Navysnipe
Old 11-01-2009, 12:49 PM   #7
nickp51chevy
Re: Leaf springs
I was an EM for 5 1/2 years and now I'm unemployed and a full time student. it's awesome
Had;
