10-31-2009, 11:59 AM | #1 |
body lift
hey i have a 71 and i was thinking about a body lift and put some big treads on there. i like them jacked up lol. any thoughts on it? should a make my own body lift or just buy one.
10-31-2009, 04:23 PM | #2 |
its all about the +6 inches
Re: body lift
moved to the 4X4 forum
10-31-2009, 11:34 PM | #3 |
Re: body lift
You can put a body lift on fro probably under $100 bucks. It doubt that you will be able to run that much bigger of a tire than you are now. Maybe one size bigger. A body lift will not help ground clearence at all. A body lift can also mess up your heating/cooling in that the radiator will sit higher than the fan. If you want to run bigger tires I think you would be better off putting your money towards a suspension lift.
11-01-2009, 12:15 AM | #4 |
Grease Monkey
Re: body lift
Performance Accessories Body lifts are about $150 for 67-72. Mudder is right about the fan. I am building a motor when I did my BL, so I just upgraded to electric fans. BL affect cooling, steering shaft, trans linkage, T-case shift linkage, fuel lines, and brakelines from MC. It can easily be overcome, but takes some patience and thought process. Let me know if you end up going with a BL and I'll be more than happy to give you some pointer.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
11-01-2009, 08:26 PM | #5 | |
Dually Pride
Re: body lift
i understand what you're saying, but no matter what, aren't your axles limiting factors in ground clearance, not lift? lift allows bigger tire, which puts more distance between the ground and the axle, gaining ground clearance. like all the rock crawling guys who run big tires and no lift
If I have to explain, you wouldn't understand. '74 Chevy C-30 350/4 speed/dually '94 Ford Ranger |
11-02-2009, 01:06 AM | #6 |
Re: body lift
A body lift will enable you to run bigger tires but a body lift will not give you more grround clearance. larger tires and wheels will add to more GC. Moving up from a 33 to a 35 inch tire will give you 1 inch of ground clearance.
11-02-2009, 06:04 PM | #7 |
the pollock
Re: body lift
you also have to consider suspension flex
adding a body lift (in my honest opinion) just "looks cool" but it also exposes your gastanks more and dosent give you and "real" benefit besides looking cooler in the mall parking lot
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
11-02-2009, 07:53 PM | #8 |
Re: body lift
so what type of suspension lifts do you guys think are the best for the price?????
11-02-2009, 08:30 PM | #9 |
the pollock
Re: body lift
what sort of height do you want?
what are ou going to use the truck for? how much are you willing to spend on tires? i spent 1600 on a set....... i have an 8 in lift, 37's and a built 350 on an 83 long bed (click link in my signature) the site also has a search function in which you can look thru all the threadsin which this same question is asked
11-02-2009, 09:21 PM | #10 |
Re: body lift
well i was thinking around 4 in. i am 15 so my budget is pretty limited for tires lol i doing a frame off so i wont be ready for treads and things till this coming summer but i like to look ahead and dream haha
11-02-2009, 09:23 PM | #11 |
the pollock
Re: body lift
well take the time to research and learn...
a 4 in lift is good man , look in the 4x4 section for the lift and tire charts, and jsut look around you got plenty of time to figgure out what you want. you can also go to the 4x4 project and builds section and see what others have done
11-02-2009, 09:39 PM | #12 |
Re: body lift
hey thanks you really helped
