Help Me With My Rear End
I found a Ford 8.8 rearend from a 97 ford explorer. It has 373 gears and posi with disc brakes Just wondering if this would be a good swap for my 12" Gm none posi rearend ?Truck has leaf springs? Also planning a 5.3 4l60e swap.
What do you all think? Thanks Again
Rolled the dice and lost!! ![]() Check Out my 71 build http://67-72chevytrucks.com/vboard/s...d.php?t=375158 |
Never Ending Projects
Re: Help Me With My Rear End
Having used this rear end in a '27 Model T roadster I built, I think it is going to be too narrow. I know it is a couple inches narrower then my Cherokee rear end, which is narrower then my '68 C10 rear end.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
ttt
