Old 10-31-2009, 04:55 PM   #1
eric67m
eric67m's Avatar
Sway bars?
Does anyone with a 67-72 4x4 run sway bars, either front or rear. I assume you could retrofit from the newer years? I assume that it would not do as well off road but might be better on road. You could always use ord disconnects for off road.
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
Old 10-31-2009, 08:51 PM   #2
snj8198
snj8198's Avatar
Re: Sway bars?
i just added a sway bar to the front of my '71. i used 2 short sections of 2x4 box tubing, traced the contours of the front cross member on one closed end of each piece, cut the trace out with a plasma cutter, lined up a set of brackets with new bushings, drilled holes on the opposite closed end, and bolted it in. I was done in about 3 hours including coffee drinking. I plan on using ORD disconnects as well. -steve
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 10-31-2009, 11:19 PM   #3
eric67m
eric67m's Avatar
Re: Sway bars?
Steve, could you post a picture?
I just figure most of my time will be on road when my truck gets finished, but I have a sway bar kicking around so I might as well use it. I figure I could always add disconnects.
Any body run a rear? I have one that was added onto a 14 bolt that I had. The brackets seemed pretty cheesy (hose clamps if I remember correctly). I think I only have the bar and would figure a better mounting if I use it.
Old 11-01-2009, 04:43 PM   #4
snj8198
snj8198's Avatar
Re: Sway bars?
i will snap some shots of what i did and try posting them tonight. gotta study up on posting pics. i've never submitted pics of my truck here. i think i'll start a new thread also to show off the rig a bit.
Steve
Old 11-02-2009, 02:33 AM   #5
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Re: Sway bars?
The axle tubes are a little smaller in diameter (~.2") on my '71 and '72 compared to the '73-ups I've measured which would make the U-bolts for the front swaybar mounts a little looser than intended. Is this close enough to ignore?
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 11-03-2009, 03:21 AM   #6
Billhilly
Billhilly's Avatar
Re: Sway bars?
I choose to go with a pair of Speedway Engineering bars. Time will tell how they work out. No five minute job but I believe it will improve on road handling alot. Yes I will loose some offroad articulation, no disconnects at this stage.
Build thread with pics here -
http://67-72chevytrucks.com/vboard/s...d.php?t=217490
1972 K2500 Long Box
400/350
Billhilly is offline   Reply With Quote
Old 11-03-2009, 08:34 PM   #7
w314speed
Re: Sway bars?
From a different view!!
I have a 72 K20 and son has a 72 K10. We are replacing the front crossmember with one from the late 70/early 80, so we can run the sway bar from those years. While we are replacing that crossmember, we are installing the steering gear support plate on the frame rail. My son completed the frame /crossmember work, but not the finished product.
Thanks, Dan
w314speed is offline   Reply With Quote
Old 11-07-2009, 10:10 AM   #8
badpeanut
badpeanut's Avatar
Re: Sway bars?
Thanks, Dan
Do you have any pictures (frame/crossmember work or finished product) you could post?
'70 GMC LWB trailer
Old 11-08-2009, 01:52 PM   #9
snj8198
snj8198's Avatar
Re: Sway bars?
i spent yesterday monkeying with my camera and for some reason it is not working. i am sorry eric67m but i am unable to get you the pics you requested. when i get home from work again next weekend i may go camera shopping so i can finally post pics of my toy. good luck to you thou on your project. hope it goes well. -steve
Steve
Old 11-08-2009, 11:46 PM   #10
eric67m
eric67m's Avatar
Re: Sway bars?
Thanks,
I figure I will use my front bar. I will need to make mounts for where it attaches to the frame. I think I could make my own disconnects.
I think that I am missing many pieces from my rear bar. I cannot figure how it would attach. Some time i will try to post a picture of what I have.
