10-31-2009, 09:48 PM | #1 |
Any point upgrading to 1 1/4 rotors
I am going to be ordering my drop spindles soon and was just wondering if it would be a good idea or not. Would it improve braking? I know I would have to replace my calipers and rotors, anything else I am missing?
10-31-2009, 09:54 PM | #2 |
Re: Any point upgrading to 1 1/4 rotors
basically the thicker rotors are more resistant to warping and are better for towing because they can take more heat before they warp.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
10-31-2009, 10:03 PM | #3 |
o k, the 1 1/4" spindles are $60 cheaper than the 1" spindles. So that would help cover the cost of rotors and calipers. But I wont be doing any towing so maybe its not worth it
10-31-2009, 10:27 PM | #5 |
BAD BOW-Silverado XST
Slotted and dual piston calipers are the best upgrades.
10-31-2009, 10:48 PM | #6 |
Your absolutely right, I was looking at it mainly because of the price difference on the spindles. Looking on autozone's website calipers, rotors, and pads, would run around $88 dollars. So if I order the cheaper spindles I could in effect get front brakes for $22
10-31-2009, 10:49 PM | #7 |
Badass
if your doing that you mine as well get new bearing and seals
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
10-31-2009, 10:52 PM | #8 |
Hey 3r!c84, are you talking about the wheel bearings and seals? I was thinking it would be a good idea to replace them with the spindles
10-31-2009, 10:57 PM | #9 |
definately replace the bearings with the spindles. no sense in putting old bearings on new parts. they are too cheap to worry about not just replacing them with fresh parts
11-01-2009, 12:03 AM | #10 |
At least one side on the rotors use different bearings anyway (1.00" vs. 1.25")....
11-01-2009, 08:23 AM | #11 | |
Watch out for your cornhole !
11-01-2009, 09:32 PM | #12 |
yeah but I just want to make sure I wasn't missing something.
So if I get the 1 1/4 spindles I just need to get new calipers, rotors, pads, wheel bearings, and seals right? |
11-01-2009, 09:49 PM | #13 |
that should cover it. while your going to have everything apart new hoses probably isnt a bad idea either. if you cant remember them being replaced they probably need it. keep in mind brake hoses rot from the inside out so you cant always tell when are going bad from the outside
11-01-2009, 09:53 PM | #14 |
Ok, thanks for the advice everyone. And cableguy I'll get a price on lines while I'm at it
