Old 10-31-2009, 09:48 PM   #1
68C10HotRod
68C10HotRod's Avatar
Wiring & 1/4 window question
New to the Burb and the one I picked up ('72) has a few issues. I've always loved these monsters & the wife isn't real happy I got it so getting it road worthy QUICK is important.
The wire harness in this thing has cuts & splices all over it (motor, dash, tail). Only 1 headlight works at present & nothing else on the exterior. So, do the Burbs use a taillight harness from the long bed trucks OR is there a better way (tail harness is the worst butcher job). Figured I'd start with tail/brake/backup lights & work my way forward.
It's also missing the drivers 1/4 window in the 4th dr panel. How do you replace that window?
I want this to be my daily driver while I work on my 68 truck so any suggestions from you pros would be greatly appreciated. TIA!!
Bryan
'52 Bel Air 2dr HT - in pieces
'68 C10 - 6cyl/4spd REMOVED, LT1/T56 to be installed
Any society that would give up a little liberty to gain a little security will deserve neither and lose both.” - Benjamin Franklin
"And those who know what's best for us, Must rise and save us from ourselves" - RUSH lyric (mockery)
68C10HotRod is offline   Reply With Quote
Old 11-01-2009, 12:10 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Wiring & 1/4 window question
the tail light harness is burb specific since it is longer, going up into the roof and back down instead of going under the truck.
I suspect that not-a-door window will be a total b!tch to replace... i hope someone has some advise.
