Old 10-31-2009, 09:57 PM   #1
surfacerust
spindle/hub swaps.. for the 1000th time
hey kids, i did a thread search and cant quite find what im looking for.
ive got a 70 LWB C10. manual drums.
i want to put the 5 lug spindles on the front but i dont want to upgrade the brakes or anything. just change the wheel pattern.
in my head its as simple as a hub and drum swap.
what is the wheel pattern anyway for the 5 lugs?
the reason is i got a sweet set of 15x5 et mags that i think are 5 on 4 3/4 and some nylon coil spacers
the rear ill leave 6 lug,
any ideas?
surfacerust is offline   Reply With Quote
Old 11-01-2009, 12:22 AM   #2
BAGNDRAGIT
Just Not Low Enough!
BAGNDRAGIT's Avatar
Re: spindle/hub swaps.. for the 1000th time
im pretty sure when you go disc, you need to add a power booster.
and you will need to change the proportioning valve.
oh and you will need to swap to 71/72 balljoints and tie-rods, and i believe drag link as well.
im sure someone will chime in...
NEED ELECTRICAL HELP? ASK ME!
67-72 Full Wiring Diagrams
Lots Of Info, TAKE A LOOK
1967 Chevy C-10 Shortbox Bagged 327 4spd
Previous:
1971 Chevy C-10 Short Sep I6 Auto (Traded)
1973 Chevy C-20 *THE REDNECK BATTLE TRUCK*
2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P.
1969 Volkswagen Bug
This is my first meeting, I have a horsepower problem.
BAGNDRAGIT is offline   Reply With Quote
Old 11-01-2009, 12:23 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Discs don't need power boosters, they've made millions without from the factory.
He specificly said he does NOT want to swap the brakes.
you won't find any truck 5 lug drum stuff... not GM stuff anyways.
GM truck 5 lug stuff was 5 on 5.
You have car wheels.
Old 11-01-2009, 12:24 AM   #4
BAGNDRAGIT
BAGNDRAGIT's Avatar
misunderstood your q. woops.
LHM is right. as usual
Previous:
1969 Volkswagen Bug
Old 11-01-2009, 08:32 AM   #5
surfacerust
so any 67-72 5 lug stuff was disk brakes only huh?
AND the patterns wrong... bummer.
gotta swap spindles and all to get the 5 lug on the front dont I.
Id still like to try it.
i got the wheels and tires for a song(a sliding rear window to be exact)
i may still try to go thru with it and find another set of wheels.
Old 11-01-2009, 10:29 AM   #6
BADPURPLE70CHEVY
406 Powered
BADPURPLE70CHEVY's Avatar
I finished doing what your trying about a month ago and its fairly simple. If possible find you a donor 71-72 2wd truck for parts.
70 GMC
68 c10
2002 silverado
72 4x4
BADPURPLE70CHEVY is offline   Reply With Quote
Old 11-01-2009, 10:48 AM   #7
Longhorn Man
And there's another response typed without reading the actual thread.
Old 11-01-2009, 11:08 AM   #8
BADPURPLE70CHEVY
406 Powered
Read the thread LHM IT WAS JUST A SUGGESTION.............
70 GMC
68 c10
2002 silverado
72 4x4
Old 11-01-2009, 11:24 AM   #9
surfacerust
oh well, ill prolly put the wheels on the front of the Impala.
but i am gonna put the coil spacers and stock springs back in the 69 and leave the 6 in drop in the back.
ill leave the 225/70s on rallys and ive got a *****in set of 15x12 aluminum spokes from early 70s for the back. put some meats on em
Fink all the way!
thanks for your help fellas!
