Old 10-31-2009, 10:08 PM   #1
akpackfan
Cab and radiator body mounts.....
'71 C10. Two questions about changing out the cab and radiator rubber body mounts. Do I have to take out the fuel tank to change the rear two cab mounts? It looks like the tank is right on top of the bolt heads. I assume if I want to change the bolts I will have to.
Second question, I have an aftermarket large aluminum radiator that sits right on top of the front two radiator body mounts so I would assume I'll have to remove it to change the rubber mounts and bolts?
Thanks for any input.
akpackfan is offline   Reply With Quote
