Old 01-19-2003, 04:22 PM   #1
Mountain Man
resealing 350 oilpan and th350 tranny pan - Questions
I will be resealing my 350's oilpan this spring, also need to dump the th350 tranny pan and change oil/filter.
What all is involved in resealing the engine oil pan? Do I just use a silicone sealant, and which brand? Also, are there any components in the way that have to be removed, or can I just unbolt the pan with no issues?
As for the tranny pan, are there still kits available that include the paper gasket and filter? I am going to mount a tranny temp sending unit on my pan, while I have it off.
Have not done this resealing of the engine/tranny before, and want to make sure that I do not overlook any thing or use the wrong sealant. I only want to do it once.
72 C10 Cheyenne Super
Full trim
Factory tach dash
A/C dash
Factory tilt
350 / 350 power train - with Edelbrock components.
Mountain Man is offline   Reply With Quote
Old 01-19-2003, 05:59 PM   #2
bigjimzlll
bigjimzlll's Avatar
on the oilpan...go with a one piece fel-pro gasket...it is the best way to do it..easy.. no sealant needed.,
jim
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 01-19-2003, 07:07 PM   #3
Mountain Man
ttt, I still need to know if there are any other components in the way, or can I just unbolt the pan, reseal, and assemble.
Does every one agree that a Felpro gasket is the best way to reseal the pan? Sounds like a good idea to me.
Full trim
Factory tach dash
A/C dash
Factory tilt
Old 01-19-2003, 07:42 PM   #4
marcuspboldt
Registered Abuser
marcuspboldt's Avatar
The way I did mine was to completely remove the pan, I kinda wanted to see if there was an extra parts in the pan, and it's the only way I know of to really get the pan clean of all the old gasket material.
Of course I had to paint the pan while I had it off!
To do this I had to remove the motor mount bolts and raise the motor up a few inches.
It's very important to get all the old gasket crap off, that includes the tranny pan, which is usually pretty easy to clean. And I used RTV blue on the oil pan gasket.
The filter and gasket for the tranny is in a filter kit.
marcuspboldt is offline   Reply With Quote
Old 01-19-2003, 09:40 PM   #5
71k5
The one piece is the way to go; worked great on mine. Your cross member may be in the way for dropping the pan; shouldn't need any sealant on either gasket...
71k5 is offline   Reply With Quote
