Old 11-01-2009, 07:19 PM   #1
71on20s
4x4 cabs vs 2wd cab
Are there any differences in the two i came across a good 4x4 cab but my truck i have now is 2wd could i use the 4x4 cab on 2wd setup thanks for any help
71on20s is offline   Reply With Quote
Old 11-01-2009, 07:38 PM   #2
Wildstreak
"something witty here"
Wildstreak's Avatar
Re: 4x4 cabs vs 2wd cab
I was also wondering this and vice versa how well 2wd cabs interchange with 4wd
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 11-01-2009, 07:53 PM   #3
rsavage
rsavage's Avatar
You didn't identify the years you are comparing. 4X4 will have the high hump. Two wheel drive not necessarily as it is based on transmission it came with. Center grille brackets are different for various groups of years. The 71 and 72 cabs have a suspended gas pedal and a vent in the driver's side door jamb. Also 71 and 72 rear view mirrors are windshield, not cab roof mounted. I'm sure that there are other minor differences that I can't think of or don't know.
rsavage is offline   Reply With Quote
Old 11-01-2009, 07:54 PM   #4
fine69
fine69's Avatar
Yes you can use the 4x4 cab on your 2 wheel drive.
Only difference is the center hump in the floor. 4x4s have a bolt in hump.
Most 2 wheel drive, turbo 350 trucks have a small hump.
But the bottom line is you can use it.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 11-01-2009, 08:00 PM   #5
71on20s
Thanks for the information that really helps me out definitely gonna buy that cab then thanks again
