01-19-2003, 05:31 PM | #1 |
Need pic of alt. brackets
I need a pic of the correct alt brackets for a 327 With camel hump heads , no acc. holes . I'm running Rams horns with holes on the end . Thank's for any help .
01-19-2003, 10:15 PM | #2 |
well what i got out of it, im running the same exact thing as you only on a 383, looks just like a 327 tho, you can buy
"F" bracket out of jegs or your local store, and then there is the long adjust bar, and that comes off of your waterpump i think.. and the "f" bracket bolts to your ram horn. hope i helped its kinda hard to explain.. matt
1971 k5 blazer 80k mike survivor 1972 3/4 ton 4wd Cummins 12v 1967 swb 2wd 427bbc 1968 4wd shortbox 1971 Cheyenne swb k10 unrestored 1971 Cheyenne super 40k 402bb survivor 1967 Chevy k10 (first truck) 1968 L78 camaro survivor 18k miles 1969 z28 survivor 60k miles 1969 z28 survivor 39k miles 1969 z28 rs survivor 80k miles |
01-20-2003, 09:57 AM | #3 |
I don't have camel hump heads but I do have a stock 68 327 with ram horn manifolds. The DS ram horn does have the acc mounting holes. Everything's out of the truck so I could snap some pictures if that would help.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
01-20-2003, 02:42 PM | #4 |
Here is a pic of the brackets from one angle. Need to take a
picture with the engine out. Sorry, it is all that I have. Jim |
01-20-2003, 06:59 PM | #5 |
Thanks Jim , that at least shows me witch top bracket I need , Tom If you could take a pick that would help. Thanks Guy's
